Shuddering on Acceleration from Stop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by this_is_nascar, Sep 23, 2020.
  1. Sep 26, 2020 at 7:35 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Where you say the vibes are reduced in 4wd, I'd replace the drivers side needle bearing with the ecgs bushing as well.
    Rust around the bearing caps is a sign of needle bearing failure in the u joints.
    Good luck in getting it figured out.
  2. Sep 28, 2020 at 4:04 PM
    this_is_nascar
    this_is_nascar [OP] Well-Known Member
    Gloucester City, NJ
    2007 TRD Off-Road
    Thanks again all. Due to some emergency here at home, I haven't had a chance to try anything with this yet.
  3. Dec 9, 2020 at 3:15 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    To close the loop on this, it turned out to be the rear U-Joint, by the axle, is how it's written up on the work order. I had it diagnosed and done at a shop of someone who I used to work for.
    I wanted to make sure I updated my thread with the outcome. Nothing grinds my nuts worse than when help is asked for and we never get the resolution.
    I appreciate all the help and suggestions offered here.
  4. Dec 9, 2020 at 5:03 PM
    LancerRevo
    LancerRevo Well-Known Member
    Phillip
    2007 Tacoma Pre Runner V6 4.0
    Based off your post, I had similar on my 07 pre runner. I had a recall done on the driveshaft and also had them install a seal while they were under there. Got rid of it thankfully!
  5. Dec 10, 2020 at 2:01 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You are going to regret not getting them all done... If one is gone the other two are not far behind it
  6. Dec 10, 2020 at 2:27 AM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    You're probably right, but it's a gamble I had to take for reasons I'd rather not get into.
