Shuddering vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tennessee98, Feb 13, 2024.
  1. Feb 13, 2024 at 8:00 PM
    Tennessee98
    Tennessee98 [OP] Well-Known Member
    2007 Tacoma supercharged
    Looking for some input on a shuddering vibration when barely rolling from a stop. Almost feels like the truck is trying to cutoff but doesn't. I can feel the vibration even when rolling in neutral. Only happens under 15mph. It just started out of the blue. Any suggestions. 07 tacoma with 3 inch icon coil over
  2. Feb 13, 2024 at 8:29 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    I had something similar happen to me.
    It was the carrier bearing. Take a peek and see.
    Tennessee98[OP] likes this.
  3. Feb 13, 2024 at 10:04 PM
    Pyts
    Pyts Well-Known Member
    09 2.7 RWD
    Stock
    Yeah, check your driveline for vibration. If it's not that, you've got quite a few potential items to consider. engine/trans mounts, vacuum leak/s, issues with combustion like fuel, spark, throttle body gunk. if you're nuts, exhaust resonance even has potential to cause some vibes. Ignition coils. your balance shaft chain tucked behind your timing chain is also a factor, at least it is if you have a 2.7L.
    Three years on, I'm still spitballing. think I might pry my wallet out of my velcroed back pocket and, after distracting the moths, buy some coils.. otherwise i'm doing the head.
    Edit: if you have a lift and some tires, driveline is an even stronger consideration
  4. Feb 13, 2024 at 11:33 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
  5. Feb 14, 2024 at 4:40 AM
    Tennessee98
    Thank you for the feedback. I feel like I have a place to start looking.
