Shudders/shakes at low rpm between 1000-2000
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nellz94$, Mar 6, 2023.
  1. Mar 6, 2023 at 8:18 PM
    Nellz94$
    Nellz94$ [OP] Member
    2018 tacoma sr double cab 4x4
    Stock
    Bought my Tacoma sr used with 36k miles on it . At 57k notice shaking while accelerating only at low rpm with light throttle . Did re alignment and rotation. Had a mechanic go through everything found the rotars were warped . Replaced those still have shaking . Driving me nuts anybody that knows or has had this issue plz let me know anything that will help thanks in advance
  2. Mar 6, 2023 at 8:20 PM
    Nellz94$
    Stock
    Gonna go in for a transmission change tomorrow hopefully works out . Also my driveline is supposedly good
  3. Mar 6, 2023 at 8:23 PM
    BlackTRD4Me
    BlackTRD4Me Well-Known Member
    Sean
    2017 Toyota Tacoma Off Road
    Bull bar with lights, Wheels on stock tires, window vents.
    U joints maybe? Or an unbalanced drive shaft?
  4. Mar 6, 2023 at 8:37 PM
    Nellz94$
    Stock
    My mechanic said everything looked ok he said he went through my whole suspension and all under . Only does it at low rpm when light acceleration.
  5. Mar 7, 2023 at 1:58 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Find another mechanic.
  6. Mar 7, 2023 at 2:05 AM
    RSOTACO
    RSOTACO Well-Known Member
    Joe
    York County PA
    2016 SR5 Barcelona 285 75 16
    Yes
    Cv axle or needle bearing?
  7. Mar 7, 2023 at 2:37 AM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    you had shudder on accel and your mechanic said to replace rotors? get a new mechanic. if an acceleration is causing a shudder it's most likely engine related, possibly transmission or other drivetrain. rotors only cause shudder on BRAKING, not slowing, braking. like brake shudder, let off and engine "brake" no shudder...brake system. if shudder on accel, that's not brake related
    But how would they warp at 50k? Unless you are towing like all the time. I have 100k on original rotors and pads and drive in shreveport so hard stops are the norm (shitty drivers) and mine don't shake one bit and never changed either (bought the truck with 30k)
  8. Mar 7, 2023 at 8:48 AM
    Nellz94$
    Stock
    It feels like after the shift points it’s shakes and shutters. Then feels like it shakes the whole truck . The rpm needle also flickers slightly up and down . I’m getting my trans fluid changed and the differentials also serviced . Definitely feels trans related
    Graylight_Taco likes this.
  9. Mar 7, 2023 at 12:46 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    It probably is. My buddies 2019 trd tacoma had a vibration like shudder at very low rpm similar to lugging an engine, than a different vibration around 1600 rpm. It wasn't terrible, but it left you knowing it was there. Dealer said it was a common issue for that trim.
  10. Mar 7, 2023 at 1:46 PM
    Brenden J
    Brenden J Well-Known Member
    Brenden
    2016 Tacoma TRD sport
    Ive had this off and on on my 2016. At first i thought it was the carrier bearing going bad but I was told it was the torque convertor. It was only on really light acceleration and below 45mph. Never really nailed down why it was happening but eventually it went away after 6 months. Kind of a blessing and a curse that i procrastinated rebuilding the torque convertor/transmission.
    Wastatehunter likes this.
  11. Mar 7, 2023 at 2:06 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Could be torque converter.
    Ricardo13x likes this.
  12. Mar 7, 2023 at 2:09 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Does this truck have a 3.5+ inch coil lift on it? or is it all stock suspension?
  13. Mar 8, 2023 at 11:21 AM
    Nellz94$
    Stock
    My truck is stock just some 265/75/r17 at tires and it went away for the most part after getting the rear diff serviced and trans fluid changed
    YF_Ryan likes this.
  14. May 5, 2023 at 6:18 PM
    Wastatehunter
    Wastatehunter New Member
    2018 Tacoma dclb trd sport
    Leveling kit 33x12.5
    Did the torque converter go out ? This is exactly what mine is doing. 2018 Tacoma double cab long bed trd sport leveling kit on 33x12.5 69k miles automatic
  15. May 5, 2023 at 6:18 PM
    Wastatehunter
    Did you find the problem ??
  16. May 5, 2023 at 6:23 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Sounds like the shudder issue people like me got on the 2nd gen. There’s a lot of people reporting low aws from the factory on the 3rd. Gen. My issue went away with a aws service and shudder fix stuff from orileys. Cheers!
  17. May 5, 2023 at 6:42 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Ya sounds like torque converter shudder, change your transmission fluid and it should be good to go. Also find a new mechanic, he's just going parts cannon on it wasting your money because he doesn't know what he's doing
  18. May 5, 2023 at 7:01 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    put truck into S5 at anything less than 60 mph. the truck races to get into 6th gear, and if you dont push on the accelerator enough to downshift, you will get the shudder. using D and cruise, or S4, S5 and foot driving, the shuuder is all but, gone. Ski
  19. May 8, 2023 at 8:42 AM
    Brenden J
    Brenden
    No, once it randomly went away, it hasn't come back. Not really sure what fixed it.
  20. May 8, 2023 at 9:36 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    try resetting the transmission/throttle learned values. mine will eventually start doing it again though. noticed it was pulling a lot of timing so started using 89 octane after resetting the learned values and it didn't do it again until i went back to 87.
