Shut off and won't restart
Discussion in 'Technical Chat' started by scarroll22, Feb 20, 2014.
  1. Feb 20, 2014 at 10:06 AM
    scarroll22
    scarroll22 [OP] Member
    My 05 V6 4.0 Tacoma shut off while pulling into my parking lot yesterday, and won't restart. The engine will turn over but won't actually crank. Also the Check Engine light, low oil pressure light, and battery light came on. Any ideas what the problem might be?
  2. Feb 20, 2014 at 11:14 AM
    gearcruncher
    Canadain bumper technician
    Check for spark while cranking .
    Check for fuel pressure
  3. Feb 23, 2014 at 3:59 PM
    scarroll22
    Replaced fuel pump already. And it's getting power, but isn't sending fuel through the lines. Any ideas about that?
  4. Feb 23, 2014 at 4:12 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    What's the check engine code? That would help.
    Don't know what you mean by turns over but won't crank?
    Battery light means charging isn't happening, did you check your belt?
  5. Feb 23, 2014 at 4:14 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    So it will crank. Turning over=cranking.
    Check the codes definitely. Go from there
  6. Feb 24, 2014 at 6:00 AM
    scarroll22
    I'll check the codes later tonight after I buy a scan tool. Thinking about the pump though, how does fuel get into the bucket that the URD pump sits in? There is pressure in my high pressure line, just no fuel. So now I'm thinking maybe I should drill a hole in the bucket so fuel can flow in?
  7. Feb 24, 2014 at 6:29 AM
    gearcruncher
    When the truck stalls , the engine light , the oil pressure light and battery light will illuminate . This is normal when the truck stalls .
    Lets go back to the fuel pressure ? you have pressure in the fuel rail to supply fuel to the injectors but there is no fuel ? Whats in the line ? air ?
    If you have no fuel at the rail , you have a fuel pump issue or plugged filter / plugged fuel line .
    When you turn the key to run , can you hear the fuel pump prime for 3 seconds ?
    If you can hear the fuel pump prime for 3 seconds when you turn the key to run you should have fuel at the rail . Should be about 45 psi if you have a fuel guage .
  8. Feb 24, 2014 at 6:41 AM
    scarroll22
    Right, just air in the fuel lines.
  9. Feb 24, 2014 at 6:45 AM
    rdinatal
    rdinatal Member
    Lake Normanopolis, NC
    14 DCSB 4x2
    Tailgate (clamp & cable), Mudflap delete, Charcoal filter delete
    Out of gas?
    In the tank: Fuel line separation or a hole that is exposed when the fuel level is below it. = Add 5 gal and see what happens.
    -R
  10. Feb 24, 2014 at 6:54 AM
    scarroll22
    When I swapped pumps, I don't remember anything that would let fuel come into the bucket where the pump is. I added about 7 gallons last night just to make sure, thinki my gauge was broken and I ran out of gas, but no luck there. With so much pressure in the line, it makes me think that the pump is now working fine, but just doesn't have access to the fuel outside the bucket. Is there something I'm missing, or would I be ok to punch a hole in the bucket to allow fuel into it?
  11. Feb 24, 2014 at 7:04 AM
    gearcruncher
    Bucket ?
    You switched fuel pumps with something from URD .
    Help us out a little . More info the better chance we have of diagnosing this .
    Got any links to the pump you installed ?
    what you are trying to do ?
  12. Feb 24, 2014 at 7:06 AM
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Turning over usually refers to starting.
  13. Feb 24, 2014 at 7:20 AM
    gearcruncher
    Wondering if you have an air lock . Would be a matter of simply holding the shrader valve down until you see fuel at the rail . How long did the truck run after you installed the pump ?
  14. Feb 24, 2014 at 7:44 AM
    scarroll22
    New fuel pump: http://urdusa.com/Fuel-Upgrades-Fue...uel-Pump/Filter-Upgrade-Kit/product_info.html
    And here's a picture of the original fuel pump assembly.
    http://www.aliexpress.com/popular/toyota-fuel-pump-assembly.html
    The URD pump came with step by step instructions to replace the existing pump with their new one. The bucket I'm referring to is the bottom of the original pump in the 2nd picture. I remove the pump from the bucket, and mounted the new one.
    I dropped the tank, removed the old pump and strapped the new one on, and reinserted the whole assembly into the tank, and reconnected the fuel lines.
    I cranked the engine, but it wouldn't fire. I did however get it to start with starting fluid.
  15. Feb 24, 2014 at 7:45 AM
    Navar
    Corona CA
    If you are getting a check engine light...go get it scanned.
