Shuttering when braking??
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Aug 12, 2010.
  1. Aug 12, 2010 at 9:50 AM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    So the other day i was driving and as i applied the brakes the truck started shaking like the rotors where really really warped, i mean the brake pedal was surging and the whole truck was shaking. So i cut my rotors and installed new OEM brake pads. The problem is still there though? i have a feeling that its not brakes anymore though. I have no idea where to start?!?!? :(
  2. Aug 12, 2010 at 11:48 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    Mine does it every once in awhile. I don't think much of it tho.
  3. Aug 12, 2010 at 11:49 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    bad rotors? ABS recalibration?
  4. Aug 12, 2010 at 1:25 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    well mine is so bad that it feels almost unsafe to drive/
    i guess i could be rotors but i had the warp cut out and there is still i good bit of material left.
    and i dont have ABS
  5. Aug 12, 2010 at 1:47 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    i just had my brakes redone through and through, they found some missing parts in the driver side front caliper that had mysteriusly fallen out when my truck had started to shudder i figured it was the rotors too but they were perfectly fine
  6. Aug 12, 2010 at 4:53 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    Sounds like rotors. Even though you had them resurfaced you still may need a new set of rotors.
  7. Aug 12, 2010 at 5:46 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    well i went to adjust the rear drums today and the pads are cracking and the drums are warped. :( so those need to be replaced but i am thinking its not the main source of the problem. i gues i will replace the rear parts and if that doesnt fix it i will get new front rotors.
  8. Aug 12, 2010 at 5:50 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Here is what i found on my rotors, if the lug nuts are not all torqued to the specific rating, it will warp the rotors. Make sure all the lug nuts are torqued to within a half pound of each other.
    Also if you have done any heavy braking and then got them wet that will also screw them up.
  9. Aug 13, 2010 at 5:00 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    well i put in new front rotors and it got a little better it only really happens now between 20-35mph braking. i guess i will do rear drums next :(
