Shuttering when stopped?
Discussion in '4 Cylinder' started by Kavik, Feb 23, 2018.
  1. Feb 23, 2018 at 9:02 AM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Here is the run down,
    Details:
    -2nd gen
    -reg cab
    -2.7l
    -5 lug
    -automatic
    When stopped at a stop light, my RPMs lower to around 500rpm and the truck starts to shutter. After gas is applied the shutter immediately stops and all is normal. Something to consider,I do need to replace my u-joints but I don't think that would cause a shutter when stopped?
    Things I have tried:
    -Cleaned throttle body
    -Replaced air filter
    -Checked vacuum lines
    -Cleaned MAF
  2. Feb 23, 2018 at 9:06 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    I had that happening to me if I remember correctly it was the ujoints. You may be able to fit in the tsb they just sent out about ujoints.
  3. Feb 23, 2018 at 11:57 AM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Already contacted Toyota and I don't have any outstanding TSBs for my truck, I have a feeling its the u-joints.
  4. Feb 26, 2018 at 1:14 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    How could the U-joints cause this problem if it happens only when the vehicle is not moving? Honest question... curious...
  5. Feb 26, 2018 at 1:45 PM
    Johndh25
    Johndh25 Member
    I had the same problem. I cleaned the MAF sensor, the throttle body, replaced air filter, and spark plugs. All smooth now.
    So, did you do the plugs too? How many miles on them?
  6. Feb 27, 2018 at 7:22 AM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Didn't do plugs. I did mine around 100,000 miles and the truck currently sits at 139,000. If the issue persists I will consider it.
    I am curious to this as well. It has yet to be explained to me.
  7. Feb 27, 2018 at 7:39 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I don't understand how bad u-joints would cause the truck to have a low idle...if a motor idles low enough, it shutters which it sounds like that's what you're experiencing. I know that on 1st gens experiencing this problem it's usually recommended to inspect and clean your IAC (idle air control) valve.
    Any check engine light codes?
  8. Feb 27, 2018 at 7:44 AM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    My thoughts exactly. No codes and I will look in to the IAC as that hasn't been mentioned yet.
  9. Feb 27, 2018 at 7:48 AM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
  10. Feb 27, 2018 at 7:58 AM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Used any fuel injector cleaner lately?
  11. Feb 27, 2018 at 8:31 AM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    I haven't used any.
  12. Feb 27, 2018 at 9:19 AM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    I would try that or get the injectors cleaned if it were mine
  13. Mar 1, 2018 at 12:32 PM
    DGXR
    Friend
    Sacramento, CA
    Normally my idle (full temperature, in gear) is at 600 by the tachometer (4-cylinder automatic). Around once every 3-4 months it will have a slightly low idle at a stop, around 500 I guess. Seems to happen on hotter days. The low idle does cause some extra vibration in the truck cab, it is not severe but it is annoying. This is not normal but it's not really a problem or concern either because the issue quickly disappears. I do clean the TB and MAF every few years, stay on top of maintenance, and run injector cleaner every 3-4 tanks. Not sure if this is helpful but wanted to toss in.
  14. Mar 1, 2018 at 4:21 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    My 2TR gets all weird at idle sometimes, exactly as you describe, usually only happens after a super high vacuum condition like crawling down a steep long slope in 4LO. It will idle low like 500 or just below, vibrate the truck a bit, and return to normal after a few miles or a couple engine restarts. Others have reported this issue. It's never stalled and it seems to run fine so I just let it pass and go about my business.
    I posted about it here: https://www.tacomaworld.com/threads/2tr-fe-low-idle-after-steep-descent-in-4l.429933/
