Sick of that TPMS light? Give this a try!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757yotas, Aug 27, 2018.
  1. Aug 27, 2018 at 7:43 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
  2. Aug 27, 2018 at 7:51 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    interesting. sub'd for update on long term.
  3. Aug 27, 2018 at 7:58 PM
    757yotas
    Virginia
    2007 TRD Sport
    Ive had it for 11 months with zero issue so far
  4. Aug 27, 2018 at 8:05 PM
    POOLGUY
    JEFF
    ALABAMA
    cool. :thumbsup:
  5. Aug 28, 2018 at 12:39 AM
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    how about just replacing the sensors....not that much $
    PzTank likes this.
  6. Aug 28, 2018 at 4:05 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Go to Amazon and buy replacement sensors and have them installed. It ain't exactly cheap, but a lot cheaper than buying from Toyota. Since I've had vehicles with TPMS sensors I've had 3 different situations where I ran over something in the road that resulted in a rapid tire deflation. Once while traveling at 75 mph. Having a warning light come on gave me enough time (literally just a few seconds warning) before the tire was completely flat. Losing a tire at 75 mph isn't something you want to do.
    https://www.amazon.com/Genuine-Toyo...2007+tacoma+tpms+tire+pressure+monitor+system
    Doing a hack job on the wires opens up the OP to a lawsuit or possible prison term for negligence if he ever has a blow out at 75 and ends up killing someone else.
    Alexely999 likes this.
  7. Aug 28, 2018 at 5:23 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    no
  8. Aug 28, 2018 at 5:28 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've had mine bypassed for5 years. Tires don't even have sensors anymore.
    Alexely999 and desertrunner24 like this.
  9. Aug 28, 2018 at 5:34 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    My light came on and I can’t reset it. I’ve tried everything. Do the TPms sensors wear out eventually?
  10. Aug 28, 2018 at 5:35 AM
    koditten
    Kirk
    Central Michigan
    Yep, batteries go bad at the 8-10 year mark.
    Alexely999 and TheDevilYouLove like this.
  11. Aug 28, 2018 at 5:36 AM
    TheDevilYouLove
    Marylandistan
    Ah! I have a 2010 so they’re 8 years old at this point.
  12. Aug 28, 2018 at 5:36 AM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    They run on a battery. So yes they go bad. And you can't just replace the battery. Oreillys carrys them as well as ebay. Then you have to go to a tire shop or toyota to get them programmed
  13. Aug 28, 2018 at 6:34 AM
    Atlas86
    Atlas86 Well-Known Member
    Ontario
    2012 Tacoma TRD Sport DCLB
    You get a blow out doing 75 and it's that bad that there's an accident, I doubt the sensors will do any good.
    koditten likes this.
  14. Aug 28, 2018 at 6:36 AM
    koditten
    Kirk
    Central Michigan
    I've never been convinced the sensors are a safety device. I'm more inclined they are present to grantee the corporate fuel economy.
    Atlas86 likes this.
  15. Aug 28, 2018 at 6:46 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    You can find aftermarket sensors for cheaper, like $25 installed- got mine for the ‘07 I had from Town Fare Tire. They described them as one of the most common replacement sensors out there.
  16. Aug 28, 2018 at 6:46 AM
    KTM753
    KTM753 Well-Known Member
    I wish the 2nd Gen was like a newer Silverado or F150 where the dash or radio has a digital screen that allows you to scroll through each tire and see the actual pressure in psi. Significantly more useful than a dash light. Is it 1 psi below the threshold or 20 psi below all the other tires?
    Some aftermarket head units have this ability if you install an interface like a Mistro or similar to retain factory features that go away when you remove the factory headunit.
    Does the 2nd Gen pressure sensors have this ability to provide psi data? Techstream show this? OBD II reader? Scanguage?
  17. Aug 28, 2018 at 7:42 AM
    Muddinfun
    Muddinfun Well-Known Member
    With Scangauge, you can monitor tire pressure and tire temperature, but... it doesn't provide multiple screens, so you have to change each individual item to what you want to see. If they don't get alternate screens figured out soon, I am tempted to get an OBD splitter and run 2 scan gauges. One for tire pressure and one for trans temp and stuff.
  18. Aug 28, 2018 at 8:11 AM
    koditten
    Kirk
    Central Michigan
    Scan gauge doesn't have the capability to monitor tire pressures. Much of everything else is correct.
  19. Aug 28, 2018 at 8:24 AM
    Muddinfun
  20. Aug 28, 2018 at 9:13 AM
    koditten
    Kirk
    Central Michigan
    I was sure you were were confused with throttle position sensor.
    I've got 2 SGII's and never knew that.
    Muddinfun likes this.
