Sick oil in my water
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MudcricketHatr, Jul 31, 2019.
  1. Jul 31, 2019 at 8:00 AM
    MudcricketHatr
    MudcricketHatr [OP] New Member
    Derek
    Base 2012 silver 2.7 4x4 SC
    Just wheels, tint, and LEDs all around
    I have noticed that my truck has been using a good bit of oil, I thought it was going out the tailpipe but I think it's going out of tailpipe and into my water reservoir. Check my water reservoir and it is a black milky substance. A very substantial amount. I don't have any water in my oil probably meaning there's more oil pressure than water pressure, what are your thoughts.
  2. Jul 31, 2019 at 8:01 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    head gasket
    PzTank likes this.
  3. Jul 31, 2019 at 8:02 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    I mean there's only one thought here: head gasket.
  4. Jul 31, 2019 at 8:09 AM
    Plucky was his name
    Plucky was his name Well-Known Member
    Carl
    Central East Texas
    2007 Reg Cab Taco 4x4 5-speed manual
    ARB Front Bumper, Wet Oakle Seat Covers, Aftermarket Stereo, OME suspension with Heavy Duty Dakar Leaf Springs
    2007 2.7l owner here — head gasket. My issues were slightly different than yours, but it’s still 99.999% your head gasket. I could add a few more 9’s probably.
    I never rule out aliens or the Commies.
  5. Jul 31, 2019 at 8:21 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    On a 2012 tho? How many miles are on it?
  6. Jul 31, 2019 at 8:28 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    If it was ever overheated miles are out the window.
  7. Jul 31, 2019 at 9:54 AM
    MudcricketHatr
    Derek
    Never overheated, she has 306740. I thought only when you have water in your oil it's the head gasket I have no water whatsoever in my oil I have oil in my water meaning the oil cooler I thought has leak by and allowed oil to get into my water.
    TheDevilYouLove likes this.
  8. Jul 31, 2019 at 10:00 AM
    MudcricketHatr
    Derek
    From what I've read your oil filter screws onto an oil cooler which water passes through to cool the oil and if it leaks it allows oil to get into your water but not water in your oil because oil pressure is higher than water pressure. And somebody please correct me if I'm wrong?
  9. Jul 31, 2019 at 10:16 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    The oil cooler was on tow package 4.0L, not the 2.7L.
    Jimmyh, MurderedTacoV2 and Skyway like this.
  10. Jul 31, 2019 at 6:04 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Compression test each cylinder..
    This might help determine what’s going on.
  11. Jul 31, 2019 at 10:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Uh-Oh!
    I agree it sounds like a head gasket has been blown.
  12. Jul 31, 2019 at 10:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It can go either way depending on the differential pressure between the oil and water.
    Drain the coolant and you will probably have a load of oil in there if it has been doing it for a while.
  13. Jul 31, 2019 at 10:38 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    That's almost half a million KM. Head gasket.
    ScottyR likes this.
