Side courtings deployed.
Discussion in 'Technical Chat' started by Marco, Feb 27, 2010.
  1. Feb 27, 2010 at 5:41 PM
    Marco
    Marco [OP] Member
    El Paso
    08 PreRunner TRD
    I bought a 2008 Toyota Tacoma TRD with the side courtins deployed, but when I turn in the engine and start moving forward let say at 5mph the back tires lock and it wont move foward but it will move backwards.
    Does someone have an idea what this is?
  2. Feb 27, 2010 at 5:46 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    perhaps something having to do with the side curtain airbags being deployed? Or and ABS issue?
  3. Feb 27, 2010 at 6:18 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah...What made the side curtain bags deploy?? And were the main bags properly replaced??
    What other damage occurred and was repaired??
  4. Feb 27, 2010 at 6:58 PM
    Marco
    Marco [OP] Member
    El Paso
    08 PreRunner TRD
    Is not replaced, but it laid on the left side. I would like to fix by replacing only the left fender and dont put a new air bags courting, can I bypass the sensor of the air bags? or some how to fix it.
  5. Feb 27, 2010 at 7:01 PM
    Marco
    Marco [OP] Member
    El Paso
    08 PreRunner TRD
  6. Feb 27, 2010 at 7:07 PM
    Brunes
    Brunes abides.
    Rotorhead
    Okay...So it laid on it's left side. Easy tip over on a trail or a ditch...or was it a tip over while driving on the roads??
    Is the frame straight? Did the owner give you any alignment specs?? My guess is that the rear end is outta square and you are going to have issues with binding at speed until you get that fixed.
    But honestly....That is a wild ass guess. It could be any number of things. Is the fluid in the rera diff full up?? Brakes adjusted right?? Rims good??
  7. Feb 27, 2010 at 7:14 PM
    Marco
    Marco [OP] Member
    El Paso
    08 PreRunner TRD
    Frame and rims is on good conditions, may be I need to go to the dealer so they can check with the computer the only think I dont want to sped a lot of money to fixed.
  8. Feb 27, 2010 at 7:17 PM
    TRDKenE
    Kenny
    Richmond, Virginia
    only thing you could do for the airbag would be to put a resistor in its place to trick the Airbag module into thinking it was still there...I don't know what size resistor to use.
  9. Feb 27, 2010 at 7:19 PM
    Brunes
    Brunes abides.
    Rotorhead
    "Good condition" like you eyeballed the frame and it looked good...or you get it looked at on a rack??? Cause a few inches one way or the other and your drive line will be all kinda FUBAR.
    Problem with buying cars that are damaged- You might be lucky and not have any hidden problems....or you might.
    Best of luck.
  10. Feb 27, 2010 at 10:03 PM
    Marco
    Marco [OP] Member
    El Paso
    08 PreRunner TRD
    Thanks
