Side mirror not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jaco46, Jul 24, 2011.
  1. Jul 24, 2011 at 4:13 PM
    Jaco46
    Jaco46 [OP] New Member
    London ON
    05 PreRunner
    I have 05 tacoma prerunner.
    Drivers side mirror motor doesn't work.
    I took the switch apart but everything looked ok. I tried to pull the mirror off but I felt like I was going to break it. Has anybody else had trouble with this? Any ideas?
  2. Jul 24, 2011 at 4:22 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Does that passenger side one work? If so, then the problem is most likely in the mirror motor itself. Hold your ear close to the mirror when trying to operate it and see if you hear any noises. This can help determine if it's the mirror or the switch. I'm gonna take a guess at the mirror being the problem.
  3. Jul 25, 2011 at 5:08 PM
    Jaco46
    London ON
    05 PreRunner
    The passenger side works fine. I can't hear any noises from the mirror. Is the mirror clipped on? I'm not sure how to remove it without a hammer!
  4. Jul 25, 2011 at 5:52 PM
    NelsonTacoma
    Tucson, AZ
    It's bolted on from the inside. You need to remove the triangle shaped trim piece to access them, may have to remove the whole door panel, can't remember. 3 10mm nuts and 1 electrical connector. Pretty simple once you open it up and see. :). Let me know how it turns out.
    Edit: if you meant how to remove the glass only ive never done it on a Tacoma. Most mirrors just pop out with a little prying. Others are bolted on.
