Side mirrors are loose
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Mar 15, 2015.
  1. Mar 15, 2015 at 6:24 PM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    Hello everyone,
    My side mirrors are becoming loose and I tried to fix it with the two screws under the mirror. However the screws too stay loose and I can't reach the end... Does anyone know how to fix it? I want my mirrors to be tight like before...
    (Toyota Tacoma 08 TRD sport)
  2. Mar 15, 2015 at 6:27 PM
    anotherreject
    anotherreject Well-Known Member
    Mine got stripped out somehow and i had your same problem, i got the screws to stay tight with an unhealthy amount of loctight
  3. Mar 15, 2015 at 6:32 PM
    bra
    Badges off
    What is loctight?
  4. Mar 15, 2015 at 6:33 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Is your mirror loose where it swings, or where it mounts to the door?
  5. Mar 15, 2015 at 6:33 PM
    anotherreject
    Loctite, i spelled it wrong
  6. Mar 15, 2015 at 6:34 PM
    moondeath
    Pa, Gardners
    It's a liquid you put on screws to keep them from coming loose.
  7. Mar 15, 2015 at 7:20 PM
    bra
    Badges off
    It is loose where it swings
  8. Mar 15, 2015 at 7:26 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Slightly larger screw from the hardware store?
  9. Mar 15, 2015 at 7:36 PM
    bra
    Badges off
    Really? I have to? There is not a way to tight them?
  10. Mar 15, 2015 at 7:44 PM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    It sounds like your existing screws have stripped the inside of the mirror housing where they're normally seated. If that's the case (and my guess is they screw into plastic) you could probably get away with finding larger screws (self-tapping) to bite into the plastic.
    Have you taken the 2 screws in question out completely and inspected the holes? It'd be pretty easy to tell if they're stripped inside if you could get a good look with a flashlight.
  11. Mar 16, 2015 at 12:07 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    he said its loose where it swings not the mounting screws!!!! read before replying lol
  12. Apr 27, 2015 at 2:43 PM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Mine is also loose where it swings.
    the torx screw underneath the hinge is fine, but id toes not make it come apart..?
    the Philips under the mirror housing (when the mirror is pivoted forward) also does not dis assemble it.
  13. Apr 27, 2015 at 2:55 PM
    FishaRnekEd
    New Orleans, LA
