Side mirrors wiggle a lot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blkturbo!, Jan 25, 2015.
  1. Jan 25, 2015 at 9:32 PM
    Blkturbo!
    Blkturbo! [OP] Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    Hey, so on my '08 Tacoma Sport, the side view mirrors have become really loose in the knuckle that allows them to swing in and out.
    So, even with very normal driving, they wiggle around a lot and I cant see shit when this is happening. I checked for screws to see if they'll tighten, but the one screw on the bottom of the mirror has nothing to do with snugging up the loose joint.
    This happened from driving on washboard roads in the past....has anyone else found a cure for this?
    I called the dealer with no help other than to buy entire new mirrors at about $250 each or something like that.
    Thanks!
  2. Jan 25, 2015 at 9:40 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    There's 3 screws in the bottom.
    You need to remove the cover to expose the other 2
    Check those first!
  3. Jan 25, 2015 at 9:43 PM
    Blkturbo!
    Sean
    Henderson, NV
    Cool! Sounds like that may work! didn't know there were hidden screws on these things.
    So I remove the 1 screw to remove a "cover"?
  4. Jan 25, 2015 at 9:51 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    No there's a small cover you remove with a small flat head right by that one exposed screw you see
    It's on the stock "L" bracket that holds the mirror to the door
  5. Jan 25, 2015 at 11:21 PM
    Blkturbo!
    Sean
    Henderson, NV
    Gotcha! Gonna mess with it tomorrow. Thanks a bunch!
  6. Jan 26, 2015 at 2:19 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    I had a POS Ford Ranger years ago, after owning it for a few years if I went over 50 the side mirrors would fold in.
    I replaced both of them, problem solved.
  7. Jan 30, 2015 at 8:01 PM
    Blkturbo!
    Sean
    Henderson, NV
    Yea, I didn't notice the cover when I looked the first time. That was it...thanks! :cool:
  8. Jan 30, 2015 at 8:16 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Lol it happens. I had that same problem when I upgraded my mirrors to the newer 4Runner ones. I forgot to tighten the screws down a bit more :p
  9. Apr 27, 2015 at 2:55 PM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    YEP, FIXED IT !
