Side Rail Cap System by KB Voodoo - NOW MADE FROM ALUMINUM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB Voodoo, Oct 14, 2014.
  1. Nov 10, 2014 at 6:29 PM
    #81
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    First prototype is in!!
    Just a few very minor tweaks to make and the first batch goes to the plasma table, then to forming, then to powder coat, then out the door....
  2. Nov 10, 2014 at 11:10 PM
    #82
    Yota64
    Yota64 Professional Threadjacker
    I like it, excited to finally see it installed.
  3. Nov 11, 2014 at 5:27 AM
    #83
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The underside is just flat steel.
    It anchors with the four bolts that hold the side rail for the cleat on, and also those two bolts near the back.
    Being made from 11 gauge steel, it is really strong. All the bolts are to the inside of the bed, so I tried to pull up on the edge of the cap from the outside, and you can't make it move.
  4. Nov 11, 2014 at 5:53 AM
    #84
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Sub'd for future
  5. Nov 11, 2014 at 6:39 AM
    #85
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I'm assuming the track goes back in place once the rail is installed correct? I'm in brother. You've got my address just let me know how much and the money will be on the way.
  6. Nov 11, 2014 at 6:55 AM
    #86
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You are correct sir!!!
  7. Nov 11, 2014 at 6:57 AM
    #87
    RearViewMirror
    Craig Christ
    Awesome!
    That will be perfect for my set up.
  8. Nov 11, 2014 at 8:37 AM
    #88
    UPR TAC
    UPR TAC Member
    When these are ready, I am in for a set + your tail gate cap. Can they be shipped together to save on shipping $$?
    Good work, I have been using the crossbars you made, the HD option would be even better!
  9. Nov 11, 2014 at 8:45 AM
    #89
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Yes sir, they can definitely be shipped together.
    Also, the heavy duty version of the crossbars is going to be cut in a day or two. I made final design tweaks to that product last night as well.
  10. Nov 11, 2014 at 8:56 AM
    #90
    Yota64
    That was my concern, way to address a potential problem right off the bat and not choose to ignore it.
  11. Nov 11, 2014 at 9:02 AM
    #91
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    People won't believe how strong these things are until they get them on their trucks!!
  12. Nov 11, 2014 at 9:04 AM
    #92
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Does it replace the existing plastic caps or go over them ?
    How thick is it compared to the plastic cap ?
  13. Nov 11, 2014 at 9:19 AM
    #93
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It's a bolt on replacement for the factory caps.
    It is 1/8" thick, where as the factory plastic cap is hollow, and it is roughly 3/8" thick.
    People with camper shells and toppers should love these. It gives a nice flat surface for things to sit on.
  14. Nov 11, 2014 at 9:31 AM
    #94
    Yota64
    This thread makes me happy
  15. Nov 11, 2014 at 9:55 AM
    #95
    OZ-T
    Peter North
    British Columbia
    Thanks
  16. Nov 11, 2014 at 9:58 AM
    #96
    PATHFINDER
    PATHFINDER Well-Known Member
    Dan
    Oxnard, CA
    2014 MGM TRD OR DCSB V6 4x4
    Leer XQ100, Toyota Skid Plate, Weather Tech Vent Shades, Firestone 2407 Airbags
    Chad - I have been on the fence for the tailgate cap. Now you have my interest. If you could make the final piece that would level the front of the box I would be in. I have a Leer XQ on my rig and have to double up the foam tape on the from to make up for the overlapping box rails...
    Can't wait to see the finished product. Recommend the same metal for all pieces for the anality in all of us.. ;-)
  17. Nov 11, 2014 at 10:06 AM
    #97
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    These side rail caps, with my tailgate cap, create a level surface all the way around.
  18. Nov 11, 2014 at 10:18 AM
    #98
    OZ-T
    Peter North
    British Columbia
    I believe he's talking about the cab end which drops down from the sides a bit
  19. Nov 11, 2014 at 10:33 AM
    #99
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Ahhhh, yes, he probably is. My caps will be a lot closer in height to the cab end than the factory caps are.
  20. Nov 11, 2014 at 10:36 AM
    #100
    OZ-T
    Peter North
    British Columbia
    Sweet
