Side Rail Cap System by KB Voodoo - NOW MADE FROM ALUMINUM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB Voodoo, Oct 14, 2014.
  1. Nov 11, 2014 at 11:34 AM
    #101
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
  2. Nov 11, 2014 at 5:08 PM
    #102
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We cut 19 sets on the plasma tonight.
  3. Nov 11, 2014 at 5:13 PM
    #103
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    subd for pics
  4. Nov 11, 2014 at 6:44 PM
    #104
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Good question!!
    Yes, there will be 1/16" thick water resistant double sided tape on top of the rail to act as a barrier between the cap and the truck's sheet metal.
  5. Nov 11, 2014 at 7:02 PM
    #105
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I like these alot! Would you consider doing a one off for Flat top fiberglass fenders?
  6. Nov 12, 2014 at 5:42 PM
    #106
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I would need some detailed dimensions of the fenders.
  7. Nov 12, 2014 at 5:56 PM
    #107
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Long bed version please.
  8. Nov 12, 2014 at 10:24 PM
    #108
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    So for your next product, please invent something that will let me anchor something like a gas can or 5 gallon bucket or milk crate or 20 lb propane tank in the front corner of the bed. Or maybe rear corner. The factory rail system is too high to do this. Thanks
  9. Nov 12, 2014 at 10:50 PM
    #109
    Yota64
    Yota64 Professional Threadjacker
    Vikes, how are you meaning to anchor it? With tie downs? Is there nothing you can do with the bed d rings and the rail system combined?
  10. Nov 13, 2014 at 4:34 AM
    #110
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Last night I started design on a modular cargo basket system that will suspend from my crossbars and drop down into the bed.
    It will be sold in as many pieces as people need, kind of a' la carte if you will.
    If you need it to span all the way across the bed, it can. If you only need it to span halfway across the bed, it can.
  11. Nov 13, 2014 at 6:39 AM
    #111
    Boogyman
    Phoenix
    Corpus Christi, TX
    Can you make a cross bar system that will be elevated out of the bed to hold a basket?
  12. Nov 13, 2014 at 6:43 AM
    #112
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    These are the crossbars that I already make: http://www.tacomaworld.com/forum/2nd-gen-tacoma-marketplace/324002-bed-brackets-sale-price.html
    These are the heavy duty cross bars that are in pre-production: http://www.tacomaworld.com/forum/2nd-gen-tacomas/348896-heavy-duty-bed-brackets-kb-voodoo.html
    This is my cargo basket that is in pre-production: http://www.tacomaworld.com/forum/2nd-gen-tacomas/348482-powder-coated-cargo-basket-kb-voodoo.html
  13. Nov 13, 2014 at 6:45 AM
    #113
    Boogyman
    Phoenix
    Corpus Christi, TX
    I've seen those but I mean like a bar that is a couple inches higher than the bed
  14. Nov 13, 2014 at 6:52 AM
    #114
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The heavy duty cross bar sits a couple inches higher than the bed.
  15. Nov 13, 2014 at 6:56 AM
    #115
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    One question...With these side rail caps being 1/8" thick and bolting between the bed sides and the cleat rail, this is going to make 1/4" less between the cleat rails. Is this going to effect the use of your cross bars??
  16. Nov 13, 2014 at 7:00 AM
    #116
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Good question!!
    The holes in the cross bars are slotted in the long direction, so we should be good to go.
    I will make double sure when I get a complete set of side rail caps on my truck though.
  17. Nov 13, 2014 at 7:02 AM
    #117
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    Thanks. Looks like another great product.
  18. Nov 13, 2014 at 7:05 AM
    #118
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    So then those with caps and tonneaus that take into account the factory 3/8" drop between the sides and bed front may have issues with only a 1/4" drop now?
  19. Nov 13, 2014 at 7:09 AM
    #119
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Yes, that sounds about right.
  20. Nov 13, 2014 at 7:16 AM
    #120
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    You ever think about making the bed brackets out of the 11 gauge?
