Side Steps Installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trib, Aug 21, 2010.
  1. Aug 21, 2010 at 8:05 PM
    trib
    trib [OP] Well-Known Member
    What better to do on a summer Saturday than mod the taco. Today I added Westin Signature Chrome side steps (part no 25-2670) and a Grillcraft chrome grill.
    There are lots of write-ups on adding grills, but I haven't seen any on the side steps. The tube-style steps were actually more difficult than installing Nfab-style steps I put on my tundra, so hopefully this will help save some folks some time.
    Tools: You'll need a 3/4" socket and ratchet, a 3/4" wrench, and a 12mm socket and ratchet. Beers are optional.
    On the drivers side, take off the 4 12mm bolts for the gas tank cover. Taking off the plastic cover will give you room for installing the rear bracket required to mount the side steps.
    You'll also want to unbolt the brake lines so you have some wiggle room when installing the front bracket. I believe this screw is also 12mm.
    Here's the tricky part--the hardware. Notice the long grade A bolt welded to a piece of steel stock. The idea is to hold onto the end of the piece of steel stock and feed it up through the frame to a hole in the frame about 12 inches in.
    The welded bolt is shown on the top, with another grade A bolt on the bottom of the bracket which will thread into the end of the tube step.
    I got a little crazy with the 3/4" wrench and tightened it too much. As a result I bent the bracket slightly. No big deal.
    Rear bracket mounted and in place. I used a little WD40 on the threads to make things go smoother.
    Threading the bolt into the tube step.
    Drivers' side front installed.
    Drivers' side rear installed.
    Side steps and chrome grill installed. My neighbor's mustang. After I was done working on my truck we got the 'stang into the triple digits. I'll try to get some better photos soon of the side steps. I did a load/bounce test (I'm 210lbs) and they seem to be very sturdy.
  2. Aug 22, 2010 at 6:57 AM
    Primersinmyshoe
    Primersinmyshoe Old Sheepdog
    St. Louis, MO
    gray, shiny, dependable
    Glock 36, spare mag
    Great write up and pics.
    Just gotta ask, what brand of beer is that?
  3. Aug 22, 2010 at 7:04 AM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    mmmm. Fat Tire
  4. Aug 22, 2010 at 7:47 AM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    ^ Sir, this is a side step thread :)
    I got a pair of side steps to keep the parking lot door dings at a minimum and got a pair like those that mount to the axle. They did not stick out very much past the side of the truck so did not work for what I wanted them for.
    Then, I got another set.. the kind that mount into the body of the truck and they were so much more easy to mount than the axle mount type and they sick past the side of the truck a decent amount.
    The body mount type may not be as strong as the axle mount though?
  5. Aug 22, 2010 at 7:53 AM
    Primersinmyshoe
    St. Louis, MO
    Glock 36, spare mag
    Axle mount? :confused:
  6. Aug 22, 2010 at 9:19 AM
    trib
    Lets see, there were several beers there: Deschutes (from Oregon), Skinny Dip (from the makers of Fat Tire in CO) and I believe a longboard ale.
    Not sure what you mean by axle. Both of my side steps on my trucks bolt into the frame rails.
    I never thought about the side steps as insurance against door dings. Just another good reason to pick up a set.
  7. Aug 22, 2010 at 2:35 PM
    Old Soul
    NC
    Frame mount, my Bad
    oops, frame mount is what I meant. It is a good thing I'm not building them, there is no telling what people would be driving around in. I used a level to plum up from the step and where the door sticks out the most the frame mount step stuck past one eighth of an inch and the body mount sticks out one half of an inch. The oval type steps really stick past a lot, but I like the look of the round step. out of curiosity, try them out by pulling up next to a car (someone you know) and see if your steps actually do block the door from hitting, would be interesting to know...
  8. Aug 22, 2010 at 5:47 PM
    05 TRD Sport
    Red Prerunner AC
    OP, sorry to further clutter up your thread.
    thanks for that info. I was just commenting on OP's pic in his side step thread :)
    I think the axle mount type would definitely be stronger than the body mount type.:D
  9. Aug 23, 2010 at 12:02 PM
    trib
    I will try to open my neighbor's mustang door and see if it makes contact with my side steps or if it hits my door.
    The oval steps appear to be much more functional in terms of preventing door dings (from cars...lifted trucks are another matter) because they protrude farther from the frame and extend the full length of the cab, whereas the step-style bars only protrude at the step point for the front and rear doors.
    Results to follow. More pics to come too if I can get some time at lunch to take truck out for some shots.
  10. Aug 23, 2010 at 1:35 PM
    jusmac
    jusmac Well-Known Member
    nice looks good
  11. Aug 27, 2010 at 6:06 PM
    trib
    More pics as promised!
    BEFORE:
    AFTER:
  12. Apr 1, 2011 at 8:46 PM
    NaYoung
    NaYoung What about my Member???
    Florida
    2011 PreRunner SR5
    3/30/2011 Purchaced, Booster Seat, Child Restraint Seat, LED cockpit lights (amber), LED tailgate bar, 3rd brake light cover (Sock Monkey!), Tonneau Cover, Westin running boards, 17" wheels, Yakima Q bar system and landsharks
    Looks really good, helps make the decision to order easy :D
  13. Apr 2, 2011 at 4:04 AM
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    Plenty of BEER !!!!!!!!!!
  14. Mar 21, 2012 at 1:21 PM
    jeratbp
    jeratbp Well-Known Member
    Jeremy
    Norfolk, VA
    '05 4Runner Sport V8
    My Westin side steps should be here today, this write up & pics are awesome.
    Thanks
  15. Oct 27, 2012 at 6:05 AM
    fletchjustin
    fletchjustin Member
    San Antonio
    2010 Red Tacoma TRD OFF-ROAD
    3" lift in the front 2" blocks in the back - 265/75r16 BFG AT
  16. Mar 3, 2013 at 7:01 AM
    Robert Bullion
    Robert Bullion Member
    Robert
    Franklin,TN just south of Nashville
    2009 Pre Runner
    Vent shades and bug deflector
    Have you tried Bud's BLACK CROWN ? It's 6% Alc.
  17. Mar 3, 2013 at 9:09 AM
    GTOJim
    GTOJim Well-Known Member
    Jim
    SF Bay Area
    2013 PreRunner TRD OffRoad V6
    I just installed the exact same ones only in black. Ended up taking them to my mechanic for the install. Paint was in the threads at the tube ends, an impact wrench was used to bolt them to the mounting brackets. Impact wrench was also used to bolt the bracket to the passenger side frame.
    My suggestion would be to bolt the brackets to the ends of the tube before bolting to the frame.
  18. Mar 3, 2013 at 10:39 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    Nice look. Thinking about doing the same w/ my truck. I had some on my Tundra and really liked them. They were used for a step up for my wife and daughter. Not needed on the Taco but still like the look.
    Glad to see that was a 2-3 beer job. Not too bad.
  19. Mar 3, 2013 at 11:03 AM
    Larry
    Larry CARL
    CARL
    seems like a lot of extra hardware and work when there are side steps that mount in pre placed bolt holes directly under the cab. :notsure:
  20. Mar 3, 2013 at 11:17 AM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Mine did just that. Installed myself - easy.
