side steps noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by atla512, Sep 28, 2009.
  1. Sep 28, 2009 at 5:21 PM
    atla512
    atla512 [OP] Member
    i installed a set of Bully side steps on my 09 DC SB. everything was fine for a few weeks then one day i kept hearing noises from the rear drivers side.
    it makes a noise everytime there is stress on the frame. im not sure how to explain this but if i go up a hill at an angle with the front passengers tire 1st i can always hear something from the rear drivers side.
    the side steps is the only thing i installed on the car aftermarket. wondering if anybody else had that issue. sorry for the crappy description
  2. Sep 28, 2009 at 6:15 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    hummm, trucks do flex. i have side bars but no such issue.
    may-be recheck all the hardware of the bars to be sure nothing came loose?
  3. Sep 28, 2009 at 6:37 PM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    is it a body mounted type or frame mounted? make sure the bolts are torqued appropriately
  4. Sep 28, 2009 at 6:48 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    ^^ I'm going to guess they are frame mounted and a bolt came loose. Did you install these are did you have them installed? Check all of the hardware to insure washers and lock washers were used and re-torque all of the bolts. If all of this seems fine look for a bad or faulty weld. Use the wooden handle of a hammer and tap along the entire length of the step and by the welds and listen for a vibration. Sounds can play tricks on you, check both sides.
