Side Steps or bars
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skeener, Jun 6, 2011.
  1. Jun 6, 2011 at 1:45 PM
    skeener
    skeener [OP] Member
    High Point N.C
    07 Tacoma Dbl Cab Trd Sport 4x4 SR5
    Does anyone know the best place to get some black side steps or bars. I want some but im having trouble deciding on which style or brand I should go with. Basically which one going to look the best on my truck.
  2. Jun 7, 2011 at 1:33 AM
    pancho
    pancho Go home Nubbs, street lights are off!
    Pancho
    Southern California
    18 Cement OR 4x4 DCSB
    Black out emblems. TRD Pro grille.
    I'm also looking. I think personally, running boards look better than tubes. But tubes if they are blacked out.
  3. Jun 7, 2011 at 4:10 AM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    i have the nfabs and have no complaints so far
  4. Jun 7, 2011 at 5:54 AM
    bayou_fennec
    bayou_fennec blah blah blah
    Austin
    05' PreRunner
    Kenwood Head Unit, Bed Mat, Weather Tech Floor Mats, Nfab Wheel 2 Wheel Step Bars, LED Bed Lights
    i bought NFab step bars through 4wheel parts. they were the only ones i could find with the bed access step. (at that time)
  5. Jun 7, 2011 at 6:33 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If your looking or are in need of a step, and are not doing any hard core off roading, I like the toyota running boards mentioned above. I think they look the best of all the step up options on our trucks. If your planning on doing some off roading, remember most tube steps, running boards, etc can increase the damage to the truck if hit and pushed into up the vehicle.
    Thats when you want to consider sliders. Typically not the best step option, but can work as a step up and will also protect the truck while off roading. Also, good for door ding protection I have heard...;)
