Side View Mirror with Turn Signal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zackk, Dec 13, 2014.
  1. Dec 14, 2014 at 1:15 PM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    If you had to run a new ground, then I repeat what I said above...maybe it is only the ground that is not grounded yet. Worth looking into if you haven't already.
  2. Dec 14, 2014 at 1:58 PM
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    No I checked for contijuity... nothing between the door wiring and the fuse... super lame
  3. Dec 14, 2014 at 6:01 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Tuning in late. .. are all 2014 pre wired at the mirror for turn signals?
  4. May 30, 2015 at 6:37 PM
    Holdstrong603
    Holdstrong603 Member
    Kristopher
    2014 White Tacoma TRD Off Road
    TRD Exhaust Blacked out badges TRD Pro Grill Baja Wheels
    So I installed the TRD sport signal mirrors on my TRD off road. Was it confirmed that they are just not grounded? When grounded will they function? All the wires are in the male and female connectors. What do I ground it to?
  5. Dec 3, 2017 at 4:15 PM
    Ted Steel
    Ted Steel Well-Known Member
    Ted
    NC
    2018 Cav Blue Pro 6MT, 2014 Baja (sold)
    Hey apoteker - ever figure this out? I have the same exact issue you have (5 wires to the harness, but the blinker wires have no juice) and I was hoping you could short circuit some of my investigation time into this...
  6. Dec 3, 2017 at 4:27 PM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    Subbed
  7. Dec 3, 2017 at 4:40 PM
    Ted Steel
    Ted
    NC
    I picked up some of these:
    https://www.amazon.com/gp/product/B00EZD6KQG/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
    ...and Dupli-color rattle-canned the mirror caps. Came out pretty good after a color sand, cut and buff, polish. I installed them today and was super bummed to find out that the wires running up the door are currently dummies. I thought I had faulty mirrors at first until I checked the wires with a voltmeter.
    robm7 likes this.
  8. Dec 3, 2017 at 4:52 PM
    robm7
    2012 TRD OR
    I really wanted the OEM mirrors oh Well my wallet is happy this can’t happen.
  9. Dec 3, 2017 at 9:11 PM
    apoteker
    Oh yeah, i figured it out... had to make my own wiring harness and run it through the door panels to the fuse panel. I installed some bed lights and used the same wiring per the Toyota bedlight wiring instructions to get the puddle lights to work. it wasnt too hard but wished there had been an easier solution.
    I am pleased that the bed lights, puddle lights and int dome lights all fade on/off with key remote so looks factory.
    Norton and Tacos4ever15 like this.
  10. Jan 25, 2018 at 1:18 PM
    robm7
    2012 TRD OR
    Is the sigal mirror wiring already ground without power?
    Or do I need to ground it?
  11. Dec 8, 2018 at 11:15 AM
    Ted Steel
    Ted
    NC
    Bringing up an old thread in an effort to get my turn signal mirrors working.
    The wire locations within this connector that @AeroCooper is pointing to, on my truck these are blank (no wires). However, I popped off the connector and touched the male pins within the fuse panel receptacle and these are in-fact 12v sources for left and right blinkers.
    My thought is that I could purchase some female terminal pins that will fit inside the factory connector, run some wires up to the mirrors and finally have some side view mirror signals.
    Does anyone have any clue how to identify the correct female terminal to get? Something like this is what I'm thinking:
    https://www.mouser.com/ProductDetail/Molex/34803-3212-Cut-Strip?qs=sGAEpiMZZMs7eK6h2EBtKnLUUhtImXeWLDWi2Fbrz/g=
  12. Dec 8, 2018 at 11:33 AM
    caribe makaira
    Caribbean, Puerto Rico
    Ted Steel likes this.
  13. Dec 8, 2018 at 11:45 AM
    caribe makaira
  14. Dec 8, 2018 at 11:49 AM
    Ted Steel
    Ted
    NC
    That's it!!! You are a genius @caribe makaira !!
    It's the middle one labeled "1.0III IDC" in your first reply. Do you by any chance... have a link? I'm searching on Mouser's site but feel like a fumbling idiot trying to sift through 1,000's of connectors.
  15. Dec 8, 2018 at 11:52 AM
    #35
    Ted Steel
    Ted
    NC
    That's exactly the connection at the mirror. I pulled the truck apart this afternoon and traced the wires of pin 4 & 5 forward into the cab. It goes into a black hole... so I'm planning on just running new wiring up to the mirror.
  16. Dec 8, 2018 at 11:54 AM
    #36
    caribe makaira
    My mistake it's the 1.0 III
    Ted Steel[QUOTED] likes this.
  17. Dec 8, 2018 at 12:01 PM
    #37
    Ted Steel
    Ted
    NC
    EDIT: Nevermind, found it. Didn't realized that was the Toyota Part No:
    https://www.toyotapartsdeal.com/oem/toyota~terminal~repair~w~w~82998-12690.html
    ---Old Post--
    That's right, that's the location I'm trying to use. Do you have any idea how to find the female connectors? I've been searching Google for nearly every variant of the text in that image:
    IDC connector
    1.0III Connector
    1.0III IDC Connector
    IDC connector 82998-12690
    etc.
    Never tried to search for something like this before so it's like reading Greek.
  18. Dec 8, 2018 at 12:13 PM
    #38
    Ted Steel
    Ted
    NC
    #38
  19. Dec 8, 2018 at 6:26 PM
    #39
    Ted Steel
    Ted
    NC
    Yes it does. It has all 5 wires going from the mirror, thru the vapor barrier in the door, down towards the cab, but then the wires seem to vaporize coming into the cab - can't find them.
    The bottom 2 pins/male terminals on the middle receptacle in that 1st pic are hot (they have 12v alternating with the blonkers). But the wiring harness/connector that goes in that middle spot is missing wires in those 2 blinker pin locations.
  20. Dec 8, 2018 at 6:38 PM
    #40
    caribe makaira
    Follow the wires to the remote mirror switch towards the connector which mates the turn signal wires towards the doors...it is a separate connector but joins the wires before sending them left n right.
