Siezed caliper bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by junkyardyote, Jan 20, 2024.
  1. Jan 20, 2024 at 10:29 AM
    junkyardyote
    junkyardyote [OP] Well-Known Member
    2010 4x4 sr5 4.0 crew cab/ 2023 TRD Offroad DCLB 3.5 auto
    Changing my wheel bearing and these mfrs are on there. I thought my impact would take them right out with 750 lbs of torque. Not so and I dont want to snap them. Anybody have this problem and what was your solution? Soaking in PB right now. Thanks
    koditten likes this.
  2. Jan 20, 2024 at 10:35 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Everyone has this problem.
    4 Toyota trucks if mine all had froze cam bolts.
    Cut an replace is the only remedy that I've found works.
    Thin disc on the grinder or Sawzall reciprocal saw. The bolts are hardened, use quality blades.
  3. Jan 20, 2024 at 10:39 AM
    Bishop84
    Bishop84 Well-Known Member
    750 isn’t much, my 1200 can’t get them sometimes
    I use a breaker bar on Toyota truck brake jobs now, I don’t even try impact.
    TXpro4X4 and 3JOH22A like this.
  4. Jan 20, 2024 at 10:45 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Those bolts have Loctite from the factory. Heat each bolt with a propane torch, then use the impact while the bolt is hot.
    Are you using any extensions or swivels with the socket? Those sap much of the impact torque.
    Jimmyh likes this.
  5. Jan 20, 2024 at 10:57 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    thread says caliper bolts. Not cam.
  6. Jan 20, 2024 at 11:00 AM
    koditten
    Kirk
    Central Michigan
    My bad. Damn bifocals!
  7. Jan 20, 2024 at 11:17 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Mine were on crazy hard when I last replaced calipers, nothing I had including a bigass cheater was even touching them, so I took the job to a shop. The mechanic said he'd never seen bolts on that tight come off without shearing first or having to be cut off. Even if yours aren't quite that bad, it does happen.
  8. Jan 20, 2024 at 11:35 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Mine were the same way.
    I had to use a breaker bar and cheater.
    And I tell you FOR SURE, it took way more than 91 ft/lbs to break them free.
    My Mid-Torque Milwaukee wouldn't touch them. It's rated at 600 ft/lbs break-a-way torque.
    The High-Torque would fit in there.
    Thankfully the hub bolts were not that tight.
    I was sweating those....
    Jimmyh likes this.
  9. Jan 20, 2024 at 12:09 PM
    junkyardyote
    Used a 3/4" conduit bender on my breaker,thanks Tn
    SR-71A, Jimmyh, iwashmycar and 3 others like this.
  10. Jan 20, 2024 at 12:25 PM
    TnShooter
    Deogee
    STOCK
    The 4 bolts that hold the bearing assembly in are torqued to 59 ft/lbs. My bolts had Loctite on the treads already.
    I had to buy a torque adapter to torque them. But good and tight is "good".
    The Axle nut is 173 Ft/Lbs.
    I did 60 and 175 and called it good.
    Caliper bolts are 91 ft/lbs
    Jimmyh likes this.
  11. Jan 20, 2024 at 2:46 PM
    junkyardyote
    thanks again,I just came downstairs to chec the spec!
    TnShooter likes this.
  12. Jan 20, 2024 at 8:03 PM
    junkyardyote
    If anybody stumbles on this,jack up the opposing lower A arm to lift the sway bar a bit and it gives you an easier time lifting the knuckle up and out of the way when removing/reinstalling the axle without damaging the seal.
  13. Jan 20, 2024 at 8:09 PM
    TnShooter
    Deogee
    STOCK
    I removed the lower ball joint bolts and pulled out ward on the spindle.
  14. Jan 20, 2024 at 8:12 PM
    junkyardyote
    I did that also,it just makes it a little easier and lighter (it seemed) for old dudes like me.Actually it made it a little easier for my wife to hold it out of the way:sandwich:
    Jimmyh and TnShooter[QUOTED] like this.
  15. Jan 20, 2024 at 8:27 PM
    junkyardyote
    One more thing to add: 163k on the Taco.
  16. Jan 20, 2024 at 10:32 PM
    TacoTuesday1
    SD CA
    PB blaster is the worst penetrant there is.
  17. Jan 21, 2024 at 9:11 AM
    junkyardyote
    Ive had decent results with it. What works better for you?
  18. Jan 21, 2024 at 9:36 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
  19. Jan 21, 2024 at 9:53 AM
    Bishop84
    I've had to mute this guy, he never supports anything just posts things like this and leaves.
    PB Blaster is obviously a good penetrating fluid thats been around for ages. I never liked the odd ball fluids like liquidwrench, mousemilk pb, rustoff etc.
    I prefer acetone based fluid, Toyota OEM Penetrating fluid is one of the best ive used. Mopar OEM is good, its kerosene based I think.
    There's loads of them, but most dont work on bolts like these because its difficult to get the fluid to creep, so all you can really lube is the surface.
    SR-71A, TnShooter and koditten like this.
  20. Jan 21, 2024 at 11:04 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Yeah, an old timer taught me a trick that SEEMS to work, when you can do it - heat the bolt from the nut end and spray on the head end, let it cool then do the opposite.
    As the heated end cools and contracts, it sucks some penetrant in, or so the theory goes.
    Bishop84[QUOTED] likes this.
