Siezed control arms dealer says not covered under warranty
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yodavego, Apr 15, 2016.
  1. Apr 15, 2016 at 5:28 AM
    yodavego
    yodavego [OP] Member
    dave
    '13 tacoma TRD off road
    3" lift/level & 255/70/r18 with zero offset wheels
    '13 Tacoma still under warranty went for 30K service. Unable to align because of seized lower control arms. Because I had it lifted only 3 months ago they won't cover it under warranty.
    Anybody have insight or suggestions?
    Is this really because of the lift?
  2. Apr 15, 2016 at 5:35 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    A lift doesn't void warranty
  3. Apr 15, 2016 at 6:23 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it does for all suspension components. has to be oem angle of the dangle or go home
  4. Apr 15, 2016 at 6:27 AM
    odomandr
    Andy
    Fort Collins, CO
    Tell the dealer to prove the lift caused them to seize. It's the design of the part leading itself to this type of issue. Magnuson moss says they have to prove it, the burden is on the dealer
  5. Apr 15, 2016 at 6:34 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    that does not fly on lifted trucks. you modify angles beyond specification
    it would fly if you replaced everything with the exact same size of part with
    some other manufacturers part...springs, shocks...etc...and kept OEM angles
    you get warranty on anything OEM because you did not change load angles
    and stresses
    but when you expect OEM parts to work and be warrantied with changed lift and angles
    therefore different side loads, stresses, and whatnot, u r pissing in the wind.
    Lester Lugnut and 2015WhiteOR like this.
  6. Apr 15, 2016 at 6:35 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
  7. Apr 15, 2016 at 6:40 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    These are correct. The Magnuson Moss act (warranty act) states that the manufacturer or dealer must prove that the aftermarket part directly caused the issue. The dealer cant just say because you have a lift, that the entire suspension is not warrantable, regardless of angles.
    PackCon likes this.
  8. Apr 15, 2016 at 6:46 AM
    yazmatic
    yazmatic Well-Known Member
    Paul
    2012 DCSB TRD SPORT
    Bilstein 5100's Eibach 620 springs SCS Stealth 6 Matte Bronze BF Goodrich All Terrain TA KO2 265/70/17 SOS Front Bumper Full Hoops Safari AirFlow Snorkel
    Interesting. I'd like to see how this ends up.
  9. Apr 15, 2016 at 6:52 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    INCORRECT how frickin simple is it to understand
    replace OEM parts with like parts, warranty applies. Like parts means it was made to copy OEM function and dimensions
    replace OEM parts with something else that introduces all new loading and stresses, NO does not hold up in court, period.
    OP needs to put all OEM back on, undo lift, and take it in like that is he wants it fixed, OR the
    dealer will juts do it for free to be a 'nice guy'
    and what does 'siezed lower control arm' mean anyway ? the arm itself
    is seized ? rough ride then ? or you mean the cams ? well those cams take
    a lot more stress if you lift the truck.
    go back to stock hide the fact you ever lifted it throw on OEM sized wheels and tires,
    then you get your warranty to fix it
    Magnuson Moss would treat angles and dimension changes or lift modifications as an INCORRECT REPAIR and that is NOT COVERED.
    But if you get all new MOOG and Federal Mogul parts (or whatever maker) to replace OEM with OEM-like parts, all OEM parts related to that that would be covered,
    2015WhiteOR likes this.
  10. Apr 15, 2016 at 7:28 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Well, all that stuff sure does sound official so I'll take it for truth. My dealership has worked on my truck exclusively since I got it and I've never had any issues like that so I guess I'm just lucky.
    OP, time for some extended LCA's for long travel.
  11. Apr 15, 2016 at 8:08 AM
    Iowa10
    Iowa10 Well-Known Member
    If I were Toyota, I sure wouldn't want to warranty suspension parts if someone lifted their truck.
  12. Apr 15, 2016 at 4:09 PM
    yodavego
    dave
    The dealer just notified me they ARE going to honor the warranty & replace lower control arms & centrics.
    The lift didn't involve any manipulation of the LCA's. Interestingly the dealership has tacomas on the lot with the same lift I had installed.
    Just in time too, warranty over end of May.
    Thanks all for your guidance.
    odomandr and Pigpen like this.
  13. Apr 15, 2016 at 5:23 PM
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    Good news
    odomandr likes this.
  14. Apr 15, 2016 at 5:31 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Everybody always throws up the Magnuson Moss Act, but so far as I know, unless you're suing the dealer over their warranty denial then it really doesn't apply to begin with.
    127.0.0.1 likes this.
  15. Apr 15, 2016 at 5:46 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Grease the cam bolts or face this issue again in a few years
    PSU Taco85 and Pigpen like this.
  16. Apr 15, 2016 at 7:01 PM
    Pigpen
    Dan
    Northwest Montana
    Currently accumulating parts to fix mine. I have my cams and bolts. Now I need bushings. Glad to hear yours was covered.
