Siezed Drum?
Discussion in '1st Gen. Tacomas (1995-2004)' started by grntruck, Jul 31, 2022.
  1. Jul 31, 2022 at 4:40 PM
    grntruck
    grntruck [OP] Member
    2002 Taco Double Cab
    OME lift. ARB bumper. Trans cooler, pillar pods, Alpine stereo, backup cam, LED headlights, Fog lights. Window tint.
    Seized drum? First for me. Decided to replace brakes, drums, rotors, and all hardware on my Tacoma. She has 310K. Front, no issues. Passenger rear, took a while to back off adjustment but simple enough. Driver side rear, got two clicks and self-adjuster wouldn't move. Drum wouldn't move. It's like the shoes are engaged. Pulled off parking cable, no difference. Opened bleed in case of pressure, no difference. Put tire on and dragged it for ten feet before it started to turn. Around the block, loosens up and works. Go to back off adjustment and it is seized again. Anyone see this before?
  2. Jul 31, 2022 at 8:55 PM
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    Your shoe may have a groove in the drum. Back off the star adjuster and use the threaded holes on the drum and use M8 x 1.25 bolts and alternate as you tighten the M8s as a puller.
  3. Jul 31, 2022 at 8:58 PM
    grntruck
    It's got a 1/8 lip. The issue is the adjuster appears to be seized. The bolts can't pull past the lip and can strip if pushed too far.
  4. Jul 31, 2022 at 9:01 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Angle grinder time? Drum is shot anyway....
  5. Aug 1, 2022 at 5:14 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You are holding the spring away from the adjuster while backing the adjuster off? Going the correct direction ? I still get confused .
    Might be time to cut the drum off .
