Signal lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaman04, Aug 4, 2009.
  1. Aug 4, 2009 at 10:49 PM
    tacomaman04
    tacomaman04 [OP] Well-Known Member
    tx
    prerunner SR5
    volant CAI helix throttle body spacer Westin Black Bull Bar Kc Slimlites130watt long range Black out Taillight Mod Flat Black Rims Flat Black Emblems Two 10' Kenwoods 1200Watt Alpine Amp Surround Black grill Flat Black Front and Rear Bumper
    Ok on the first generation tacoma the signal lights are on the bottom bumper is there anyway to make those stay on all the time with a switch and make your corner lights your blinkers? I've seen threads about them but they dont explain fully to me..:(
  2. Aug 5, 2009 at 7:07 PM
    Cheesycook
    Cheesycook Geek with a gun
    Hermiston, OR
    01 4x4 DC Tacoma V6
    You can do anything with relays. You could set both to come on with your acc power signal and have your blinker signal set as an interupt signal. One relay on each side would do it having both lights above and below running off the same relay. This should also allow your hazard lights to work properly. I do not know if on a taco this would send a signal that a light is out and cause a fast blinker. I wish I could give you details but it has been a long time since I did anything with relays on my old wrangler.
  3. Aug 6, 2009 at 5:44 AM
    JVTACOMA
    JVTACOMA Well-Known Member
    this may be what you are looking for!!!
    http://www.tacomaterritory.com/forum/showthread.php?t=106054&highlight=turn
