Significant brake fade after front brake job
Discussion in '2nd Gen. Tacomas (2005-2015)' started by axeman26, Dec 5, 2021.
  1. Dec 5, 2021 at 3:56 PM
    axeman26
    axeman26 [OP] Well-Known Member
    Will
    Bay Area
    2015 Tacoma 2wd 4cyl 4door
    Fatbob’s aal/front spacer/KO2’s/Curt trailer hitch
    Hi everyone,
    I did a front brake job a few days ago. I replaced rotors and pads. I however did not bleed the brakes. This is a low mileage 2015 Tacoma front disc brake job. I drove around the hills on a cool night and had a significant brake fade and spongey pedal. I can only assume it is from air bubbles in the lines? When I pulled over it clearly smelled like burning brakes as to be expected.
    I bled the brakes today starting with the rear and moving up to the front. Is there anything else I should check?
    Thanks!
  2. Dec 5, 2021 at 4:00 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You can adjust your rear brakes by applying the parking brake when reversing. This might help with the spongy pedal feel.
    axeman26[OP] and Geeves77 like this.
  3. Dec 5, 2021 at 5:36 PM
    axeman26
    Will
    Bay Area
    I also have been noticing my parking brake is not engaging as much as it used to. I’m assuming I’ll need to adjust the drums accordingly.
  4. Dec 5, 2021 at 5:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    And did you bed the new pads? Guessing not.
    Products used?
  5. Dec 5, 2021 at 5:43 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Adjust the drum brakes and it should stiffen up for you.
    road2cycle, Too Stroked and b_r_o like this.
  6. Dec 6, 2021 at 4:10 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    This^^^^^^^
  7. Dec 6, 2021 at 6:29 AM
    axeman26
    Will
    Bay Area
    Yes. I bed the pads.
    Kolter45 likes this.
  8. Dec 6, 2021 at 6:38 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Adjust the rears
  9. Dec 6, 2021 at 6:41 AM
    axeman26
    Will
    Bay Area
    Done and done.
  10. Dec 6, 2021 at 8:01 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Do you still smell the brakes after driving it? Can you feel any excessive heat at any one corner?
    SR-71A likes this.
  11. Dec 6, 2021 at 8:07 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    How do your calipers look? When I replaced my rotors & pads last summer, I also had the calipers rebuilt. My old pads were 4mm & 2mm & knew it was time to do all 3 at once. I went with OEM
  12. Dec 6, 2021 at 8:12 AM
    axeman26
    Will
    Bay Area
    After driving it a bit more, I no longer smell feel brake fade or spongey pedal. I think it was air in the rear lines.
    I’ve always wondered how air can enter into a “closed system”?
  13. Dec 6, 2021 at 8:18 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The smell could have been the front rotors getting hot for the first time. Sometimes they'll have a waxy coating that needs to burn off.
    Did you bleed?
    Adjust the rears?
    Small air bubbles can develop when the brake fluid down at the wheels gets extra hot and actually boils, like during a panic stop situation on the freeway. Not enough boiling to create huge pockets of air but enough to cause a noticeable soft pedal feel
    Between the shoe adjustment and the bleeding, sounds like you got it sorted out
    DGXR and axeman26[OP] like this.
  14. Dec 6, 2021 at 8:23 AM
    axeman26
    Will
    Bay Area
    Yeah. A good reminder for me to do it right the first time. I rushed the job and should’ve done all this the other day. What can ya do? Thanks for all the help guys!
    Jimmyh likes this.
  15. Dec 6, 2021 at 9:41 AM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Great video I used while rebuilding my drums, link starts at adjusting the rear drum pads
  16. Dec 7, 2021 at 2:00 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Air cannot enter a closed system.
  17. Dec 7, 2021 at 3:44 AM
    Too Stroked
    Tom
    I have to agree with this. In all of my years of working on brakes, the only way air got into a closed system was when what we thought was a closed system - wasn't.
    ZColorado likes this.
  18. Dec 7, 2021 at 5:17 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Unless the closed system wasn't actually closed or the brake fluid itself was contaminated (water) then I've never had a problem.
    However if you live in an exceptionally humid or wet area then the likelihood of contaminating the fluid is higher.
    A vacuum brake bleeder tool is a super fast way to do a fluid flush. For what the shops charge to flush the fluid you can buy the tool and do it yourself. As long as you have a decent air compressor.
    This is the tool I use, bit expensive for just one vehicle maintenance though.
    https://www.amazon.com/Mityvac-MV6835-Automotive-Accessories/dp/B0015POUXM
