Significant Brake Upgrade Needed...pics.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jan 12, 2015.
  1. Jan 12, 2015 at 12:11 PM
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Here's the deal. We have a customer that will be towing an agricultural implement on rural country roads. The implement weighs more than the truck is "rated" for...yes he knows this...let's just get that out of the way ;). He will be traveling at slower speeds when on-road.
    What would be a good performance brake upgrade for his 2005 regular cab Tacoma? SS brake lines? Pads? Rotors? Is there a kit that includes what we should install on his truck? Thanks :thumbsup:
  2. Jan 12, 2015 at 12:19 PM
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    How much does that trailer weigh? Just curious.
  3. Jan 12, 2015 at 12:24 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    that poor transmission too...
    besides better brakes i would look into addition cooling and changing out all of his oils to a better high performance type.
    That little truck is a dwarf compared to that trailer. :eek:
  4. Jan 12, 2015 at 12:25 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Drag chute? No, wait - you said he was going slow. Anchor?
  5. Jan 12, 2015 at 12:26 PM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Beyond the brakes, he could also benefit from a stronger leaf pack in the rear if he's going to be towing that quite a bit.
  6. Jan 12, 2015 at 12:27 PM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Boy I sure hope he's got trailer brakes. Some good performance pads and better fluid would certainly help but that looks really heavy. I suspect if this were real public road towing the first time a cop saw that being towed by a tacoma would result in a traffic stop.
  7. Jan 12, 2015 at 12:27 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    even leveling airbags too to help the sag
  8. Jan 12, 2015 at 12:32 PM
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    This should be good...
  9. Jan 12, 2015 at 12:36 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    a hard stop on level dry ground is still going to be scary as hell and may even jack knife..
    in other words advise against this type of towing until the owner gets a truck designed for the task.
    small and mid size trucks have their place.. that trailer belongs behind a tundra size only for safety reasons among other things.
  10. Jan 12, 2015 at 12:55 PM
    gonathan85
    Nate
    Central California
  11. Jan 12, 2015 at 12:56 PM
    gonathan85
    Nate
    Central California
    When it's fully loaded with 500 gallons of water??? ...somewhere in the neighborhood of 11,500 lb. :p
  12. Jan 12, 2015 at 12:57 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    If he plans to tow that rig around regularly, even if at low speeds, the owner would be better off selling the Tacoma and using the money he would need to spend on upgrades to put towards buying a full size truck.
  13. Jan 12, 2015 at 12:57 PM
    gonathan85
    Nate
    Central California
    Manual Transmission should stay a lot cooler than Auto Transmission...there are dozens of farmers located here in the Central Valley of CA spraying orchards this way...works real good.
  14. Jan 12, 2015 at 12:58 PM
    gonathan85
    Nate
    Central California
    I've already ordered a AllPro Exp Kit :thumbsup:
  15. Jan 12, 2015 at 1:00 PM
    gonathan85
    Nate
    Central California
    Farmers get to use what we call "Farm Husbandry." It exempts them from having to follow typical DOT regulations. Things that would get a commercial driver in all kinds of trouble are OK'd by local CHP. Farmers know what they are doing.
  16. Jan 12, 2015 at 1:00 PM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    Brake upgrade$, Tran$ wear, leaf spring$, airbag$ Might as well buy the proper truck with the right capacity. Save him the $$$$ and save the rest of us California drivers from this road hazard
  17. Jan 12, 2015 at 1:01 PM
    gonathan85
    Nate
    Central California
    Is this your input? I'm missing the part where you're recommending brake upgrades :confused:
  18. Jan 12, 2015 at 1:02 PM
    gonathan85
    Nate
    Central California
    Look. I understand your concern. Both the owner & us (as a company) are fully comfortable with this setup because it is time-tested. You're going to have to trust me on this.
    I could go into an explanation of why a small 4wd pickup is the only option for compact orchard use, but you're going to have to trust me ;)
  19. Jan 12, 2015 at 1:05 PM
    gonathan85
    Nate
    Central California
    Full-sized truck won't fit in an orchard. Trust me.
    I appreciate your concern. 100% of the use of this setup on-road will be on rural country roads that are very lightly trafficked. Also 95% of the time, this setup will be on-road from the hours of 8 pm until 5 am in the morning.
  20. Jan 12, 2015 at 1:07 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Air bags for rear. Trans cooler. And should be fine with trailer brakes. That trailer has brakes right?
