Significant Hesitation in Acceleration
Discussion in '4th Gen. Tacomas (2024+)' started by Prd78, Mar 24, 2025.
  1. Mar 24, 2025 at 11:40 AM
    Prd78
    Prd78 [OP] Member
    Hi All,
    I have a 2024 4 wheel drive sport. I usually have to pull into a very very busy street with average speeds of cars over 50 mph. Needles to say it sometimes requires me to punch it. A handful of times there has been a significant delay in response (possibly a second or more) which makes things a little scary. Anyone else with this issue?
    PEAKIT and 2016Tacoman like this.
  2. Mar 24, 2025 at 11:43 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    maybe try sport mode?
    1 second delay isnt "significant hesitation"....
    If there truly was an issue, check engine light would come on....
    IronratPR likes this.
  3. Mar 24, 2025 at 12:39 PM
    Pi27
    Pi27 Member
    Turbo lag
  4. Mar 24, 2025 at 12:45 PM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    Probably not. Turbo lag isn't really much of a thing anymore except on built motors with huge turbos.
  5. Mar 24, 2025 at 12:49 PM
    Prd78
    Prd78 [OP] Member
    "a second of more" can be significant if you are pulling out in front of a truck or car doing 50 to 60 mph and your car is just sitting in the lane doing nothing while my foot is on the gas..
    In regards to turbo lag, does that come into play from low stand still? I am at a dead stop or rolling slightly, punch it..and nothing...
  6. Mar 24, 2025 at 1:13 PM
    SchwarzeEwigkt
    Central NY
    "Turbo lag" is the time it takes the turbocharger to spool up and build enough boost to allow the engine to make significant power. It can be a cause for reduced throttle response, which is the time it takes for the engine to respond to a change in throttle input. Like I said before, turbo lag isn't really much of a thing anymore; they've mostly designed it away. What you're describing could be any number of things. There's a whole lot that happens between you putting your foot down and the truck starting to move. It sounds like poor throttle response, but it's hard to tell.
    Maybe shoot a video of you attempting the same kind of acceleration someplace safe and post it for us to see? Be sure to include the gauge cluster so we can see the meters. I'd be interested in the tachometer and the boost guage in particular.
  7. Mar 24, 2025 at 1:17 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    It’s an auto ….
  8. Mar 24, 2025 at 1:21 PM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    if you put a fourth GEN Tacoma in sport mode, you will see there is no turbo lag.
  9. Mar 24, 2025 at 1:32 PM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    wait for a bigger spot to merge into traffic... are we talking about delay from complete stop or say 5-15mph roll on throttle ?
    CrispyTacoLover likes this.
  10. Mar 24, 2025 at 2:16 PM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    :facepalm:
  11. Mar 24, 2025 at 2:18 PM
    Vidman
    Vidman Protected by Sig
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    If you get any tire spin at all the nanny’s are going to kick in and that might be your problem. Shut of your traction control and try it
    Rocko and TurboDA6 like this.
  12. Mar 24, 2025 at 3:34 PM
    MJB4450
    MJB4450 Well-Known Member
    2025 SR5 Supersonic Red
    It's the electronic throttle. Get a pedal commander or the other brand and you can adjust that so that the throttle immediately responds.
    Kolohe07, bgdv1, Burns and 1 other person like this.
  13. Mar 24, 2025 at 9:35 PM
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
    Try Tow Haul mode.
  14. Mar 24, 2025 at 10:49 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Step on the gas harder…the third gen does this too. You don’t get a whole lot out of it until the pedal is the better part of 1/2 way to the floor. When I test drove a 4G I noticed the gas pedal was pretty similar. Just the way throttle by wire is.
    People complain about power out of the 3G V6 but I have never had problems getting up to speed quickly when I needed to and my truck is fully capable of breaking the rear tires loose. You just need to step on it.
    usmc2msu likes this.
  15. Mar 25, 2025 at 3:16 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I think this is a "save the driveline" kind of thing. I notice in at least 1st gear (maybe even 2nd) it will not deliver full power. After it shifts it will let you give it all it has. I assume this is to cut down on wheel spin and also reduce driveline stresses. Not the first vehicle I've owned that was programmed like this. I have noticed this on mine.
    TurboDA6 and gmtech like this.
  16. Mar 25, 2025 at 6:23 AM
    TurboDA6
    TurboDA6 Well-Known Member
    My Nissan Titan does this. Only get 60% of the beans up to a certain speed. Also it will reduce power immediately after taking a tight turn for a second or so. Seems to be programming to protect the drivetrain and/or make the truck less likely to burn out at lower speeds and turns.
    My previous Titan didn't have this, seems to be a new thing in some trucks
  17. Mar 25, 2025 at 6:43 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I had an '07 Frontier with the 4.0 and it wouldn't let the throttle body open up 100% till 40mph. Was pretty annoying to be honest.
    TurboDA6[QUOTED] likes this.
  18. Mar 25, 2025 at 2:17 PM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    It’s not turbo lag. It’s Friday lag.
    Meaning, this post was meant for last Friday, somehow delayed due until yesterday.
  19. Mar 25, 2025 at 2:34 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Drive safer.
  20. Mar 26, 2025 at 5:42 AM
    Rojogrande70
    Rojogrande70 Member
    Red
    2025 Tacoma Ltd 4x4
    Had a pedal commander on my last vehicle (2020 Ram Eco-diesel). It completely fixed my turbo-lag issue. Thinking of adding our new 2025 Limited Tacoma as well. Seems to be okay if in Sport or Sport+ mode though for now.
