Significant Hesitation in Acceleration
Discussion in '4th Gen. Tacomas (2024+)' started by Prd78, Mar 24, 2025.
  1. Mar 26, 2025 at 6:40 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I'd imagine this is a combination of dumbing down of the throttle response for MPGs and slight turbo lag. Going from idle to needing high power right away is the perfect combo to feel lag.
  2. Mar 26, 2025 at 7:15 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    There’s no lag on mine.
  3. Mar 26, 2025 at 11:25 AM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    Pressing the ECT/power button on my SR5 proves to me that there is no turbo lag. The throttle is mapped to prevent abuse of the drivetrain. All vehicles do this, regardless of whether they are turbo or naturally aspirated.
  4. Jun 13, 2025 at 12:22 PM
    turbosix
    turbosix Well-Known Member
    dfw
    2024 TRD Pro
    i know this is a 2 month old thread i am bumping this is definitely a thing. my truck will do it randomly and it always seems to happen at the most inopportune time.
    • i always switch to sport mode as soon as i get in so it's not related to that.
    • i always remote start it so it's not a rpm/power limitation on a cold motor (also for me it happens randomly, but always at the exact same spot coming out of my neighborhood when i need to cross 2-4 lanes of potential traffic.)
    • it is not a turbo lag thing (i have worked on turbo cars since i was 14...) because if you move the shifter over into the sport shifter setting it no longer has any issues.
    • it's not a hybrid thing cause that electric motor makes nearly 200ft-lb of torque
    this is 100% a software issue and needs to be addressed. if you know your vehicle can go 0-60 in X seconds you can gauge how much space you need to safely do cross 2 lanes of traffic then you stab the throttle and your truck just pulls you into traffic with 5% of the throttle you asked for and waits a few seconds that is definitely an issue.
    LivinLaughinLovin and PEAKIT like this.
  5. Jun 13, 2025 at 12:55 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    There is no hesitation on my hybrid and there shouldn't be any on yours. Take it to a dealer that will get it fixed. It might take a few tries. Good luck.
  6. Jun 13, 2025 at 1:05 PM
    Chester Copperpot
    Chester Copperpot Member
    2024 TRD Offroad Hyb
    I notice this as well and assumed it was a traction control thing. I notice it when I am pulling out and turning, thought it was because the computer thinks it is spinning the outside tire because of the larger turning radius. But as others have said I think I have plenty of time and then there is just no power until I get straightened out. I never have the issue when going in a straight line.
  7. Jun 13, 2025 at 1:18 PM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    turbosix so your truck is broke always at the same spot? what does it do exactly?
  8. Jun 13, 2025 at 1:27 PM
    turbosix
    dfw
    2024 TRD Pro
    it doesn't do it every time. it's done it maybe 5-6 times so maybe like once a month since i WFH 4 days a week.
    leaving my neighborhood to go to work (again, truck is warm) i come up to a stop sign. i have to cross 2 lanes of opposing traffic and then make a left into one of the other two lanes.
    normally this is not an issue but those handful of times i hit the throttle going straight. again, i'm not a dickhead so i'm not cutting it close but instead of 25-50% throttle or whatever it literally just kinda rolls forward at like 5% throttle and i'm just slowly rolling across two lanes wondering wtf the truck is doing until it finally decides a few seconds later to apply the power i wanted it to.
    i thought i was going crazy but i saw this thread and at least i know it's not just me.
  9. Jun 13, 2025 at 1:40 PM
    gmtech
    Stock AF
    hmm weird. yea take it in and make sure they at least document it on a repair order. even it they cannot duplicate it. at GM we have what is called a no duplicate labor time . for whenever we have a customer come in and have a problem we cannot duplicate. that goes to GM and eventually if there is enough of them theyll look realize/ look more into it. im sure toyota has a similar thing.
    having a very good description of the problem and exactly when it does it really helps also.
    when does it do it?
    how does it do it?
    how far into the drive was it? miles and time?
    was this the first drive of day?
    was it wet out?
    what was the temp?
    were you completely stopped and then accelerating?
    were you steering at the same time?
    tell them all this and more.
    turbosix likes this.
  10. Jun 16, 2025 at 7:53 AM
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    Yes i experience this and it also chooses too high of gear if your also merging uphill. I power brake it a bit or manually shift it to first gear.
  11. Jun 16, 2025 at 9:41 AM
    IIIAWOLIII
    IIIAWOLIII Well-Known Member
    Jim
    Florida Space Coast
    2024 TRD Offroad Hybrid
    Adding my post from a transmission thread.....
    This exact behavior is why I ended the lease early on a 2023 Tundra and moved to a Tacoma.
    VERY pronounced in the Tundra (SR5 twin turbo 6), and happened about a quarter of the time. From a dead stop, if you depressed the accelerator aggressively, the truck would do a small lurch, and then just coast at a couple mph. After anywhere from a second to three (yes three), the truck would suddenly "wake up" and accelerate as normal.
    It would do this about 25% of the time, and I was able to replicate it for the dealership techs twice. All they ever did was tell me there was not TSB for it, and then reflash the ECU.
    Initially we had a few close calls, especially turning left in intersections under an unprotected green light. That happened twice before I learned not to trust the truck to accelerate reliably. After all the games with Toyota, I traded it on a Tacoma.
    I'm not happy to hear about this same behavior in a taco. FWIW, it hasn't yet happened to me in my 24 OR Hybrid.
    Lock24 likes this.
  12. Jun 16, 2025 at 9:44 AM
    LifeInMotion
    LifeInMotion Active Member
    Dave
    Washington State Cascades
    2023 Tacoma MT
    Sorry to hear this. We had a Mercedes Sprinter 2016 4x4 and they had a similar issue. Turbo lag. It took a second for the turbo actuator to spool up on demand. This left things kinda precarious and unpredictable when you really needed certainty. Ultimately a pedal controller and a tune helped a bit but never really solved it. That’s one of the reasons I went back to a manual transmission in my 2023 Tacoma. No more uncertainty.
    TurboDA6 likes this.
  13. Jun 16, 2025 at 10:37 AM
    IIIAWOLIII
    Jim
    Florida Space Coast
    This is 100% not a turbo lag issue. The engine doesn't even attempt to rev. This is likely a software issue.
  14. Jun 16, 2025 at 10:39 AM
    gmtech
    Stock AF
    it may be what they call torque smoothing, or what is used to prevent driveline banging or driveline slack build up. so since these trucks have a lot of power down low. if they let you have it all right way youd be complaining that every time you give it all the beans it just does a burn out or the traction control is active. so they keep 100% throttle held back till truck is already moving...
    this is also why the trucks dont feel as fast as the HP/TQ numbers suggest. especially the hybrids. i know mine is most impressive between 20-70mph pull onto an on ramp.. thats when it actually feels like it has stated hp specs.
    TurboDA6 and BearWithMe like this.
  15. Jun 16, 2025 at 10:50 AM
    #35
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Add a nitrous oxide system.
  16. Jun 16, 2025 at 11:25 PM
    #36
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    https://www.youtube.com/watch?v=K7LlkukE_6k
    PDKTaco likes this.
  17. Jun 17, 2025 at 5:06 AM
    #37
    CrispyTacoLover
    Sounds like it needs to go to the service center for evaluation. I can’t imagine trying to cross 380 with that issue.
  18. Jun 17, 2025 at 6:01 AM
    #38
    Alex the Great
    Alex the Great Well-Known Member
    2025 OR with factory lift
    Could this be related to "acceleration suppression"? The owner's manual states "if the accelerator pedal is strongly depressed and the system determines that there is a possibility of a collision, engine output will be restrained or the brakes will be applied weakly to restrict acceleration." The manual also states a buzzer will sound, but if you have music playing or you're so focused on traffic, you might be missing the buzzer. This only applies to automatics. If you haven't already, take a look at page 254.
  19. Jun 17, 2025 at 6:03 AM
    #39
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    That buzzer will turn down the radio a good bit, can't miss it.
  20. Jun 17, 2025 at 6:16 AM
    #40
    Alex the Great
    Everything else seems to fit. :notsure:
    Delta09[QUOTED] likes this.
