Signs of a bad water pump?
Discussion in '1st Gen. Tacomas (1995-2004)' started by agrant2312, Feb 20, 2012.
  1. Feb 20, 2012 at 6:12 PM
    agrant2312
    agrant2312 [OP] Well-Known Member
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    Intake, Flowmaster Exhaust
    What are the signs of a bad water pump my truck is leaking antifreeze from somewhere? I have 149,000 so I'm thinking my water pump us going bad? How can i tell?
  2. Feb 20, 2012 at 6:16 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Try to target where the leak is coming from? if its from beneath the pulleys at the front of the engine?
  3. Feb 20, 2012 at 6:19 PM
    agrant2312
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    Dunno its dripping off the back of the skid plate. Im going to take it off in the morning and try to figure out. Does antifreeze usually leek from somewhere if the water pump is going bad?
  4. Feb 20, 2012 at 6:21 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    yes, there is a weep hole on the pump itself
  5. Feb 20, 2012 at 6:21 PM
    acdronin
    acdronin Well-Known Member
    I dunno, does it do something like this?
  6. Feb 20, 2012 at 6:41 PM
    agrant2312
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    How bad would it leak if it did come out of the peep hole? Antifreeze has been disappearing for a few weeks.
  7. Feb 20, 2012 at 6:43 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    depends can be a few drops to a loose stream
  8. Feb 20, 2012 at 6:44 PM
    agrant2312
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    Welp that could possibly be it. Bout time to change the water pump anyways!!
  9. Feb 20, 2012 at 6:44 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    id go ahead and replace the water pump and if you havent already the timing belt too
  10. Feb 20, 2012 at 6:47 PM
    agrant2312
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    Yeah im going to. I checked the timing belt and it looked brand new compared to the new one i had so i didn't replace it.
  11. Feb 20, 2012 at 6:47 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    This ^^
    They can leak when it's cold outside and stop when the engine gets warm. Makes it hard to find the leak, the weep hole is a good place to start.
  12. Feb 20, 2012 at 6:56 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    also check to make sure those stupid hose clamps arent leaking, mine leak when the coolant is warm and stops when it cools
  13. Feb 20, 2012 at 6:56 PM
    agrant2312
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    That makes sense. It was running cold when it was leaking and its freezing here now lol
  14. Feb 21, 2012 at 11:06 AM
    TacoBill35
    TacoBill35 Member
    Bill
    SoCal
    00 Tacoma TRD V6
    Had the same issue at around 90-100k miles, losing coolant (at a slow rate) and nothing on ground. :confused:
    Took the Taco in for a new timing belt and water pump since it was due. Mechanic discovered a small leak between the water pump and engine block. Because it has been leaking for some time, the leak path started to erode the block where it mated with the pump.
    Mechanic attempted to use some kind of sealant as a band-aid fix since replacing the block isn't an option. It lasted just a short time and started losing coolant again.
    I put in some Bars Radiator Stop Leak and it worked for almost 2 years, no coolant loss. Just recently, I'm starting to lose coolant again.. maybe a few ounces every few weeks.
  15. Feb 21, 2012 at 11:47 AM
    agrant2312
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    I found the problem it's leaking out of the heater valve.
