Signs of leaks.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04LTtacoma, Feb 2, 2011.
  1. Feb 2, 2011 at 6:27 PM
    04LTtacoma
    04LTtacoma [OP] Well-Known Member
    Outer Space
    A couple days ago I pulled the dip stick out to see how much oil I had in the truck. I was missing about half a court of oil... Is that unusual for my tacoma to be burning oil? Also this morning I was looking under the truck to find some diff oil leaking by the drive line where it meets up with the tranny case. Should I call toyota and have a mechanic look at it?
  2. Feb 2, 2011 at 6:32 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Yes, but thoroughly clean all the old oily junk away and find out exactly where it's coming from. That's what they'll do to start.
  3. Feb 2, 2011 at 8:52 PM
    04LTtacoma
    Outer Space
    I will probably end up taking it to the dealership to have them check it out.
  4. Feb 3, 2011 at 3:08 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Thats not normal. It shouldnt burn or leak any oil.
  5. Feb 3, 2011 at 3:12 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
  6. Feb 3, 2011 at 8:43 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Actually just had that happen to mine was leaking at the seal where the transmission mounts to the motor. Long story short in order to fix the leak they had to drop the entire transmission $$$$. Thankfully I only had to pay $100 from my warranty deductible.
    Another thing that's common with the Tacomas is they leak oil at the oil pan. Surprisingly Toyota doesn't use a gasket at the oil pan only sealant. Anyways Good luck with everything let us know the outcome.
  7. Feb 3, 2011 at 9:36 PM
    04LTtacoma
    Outer Space
    Well, I don't think I will be spending too much... I get really good deals at toyota. :)
