silicone cv boots...Thoughts? Experiences?
Discussion in 'Toyota Trucks & SUVs' started by ndcmack, Jan 10, 2014.
  1. Jan 10, 2014 at 8:45 PM
    ndcmack
    ndcmack [OP] Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Just as the title states, I'm looking for thoughts and experiences on silicone cv boots. Are they worth the extra roughly $20? And will they hold up longer to "fin" rubbing and offroad abuse?
    Any other info you can provide would be great...
  2. Jan 10, 2014 at 8:51 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    I'm not sure. I'd think silicone wouldn't last as long with fin rubbing, stretching from turning/flexing I have no clue about. But sub'd for other opinions.
  3. Jan 10, 2014 at 8:59 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I thought the same thing, but after some online research and talking to CVJAxles, apparently they are preferred on "custom" axles for rockcrawlers, etc. That makes me wonder orquestion if it would be a good option for the angles 3” lifts do to 2ndgen axles.
    It's an option through them on the stock rebuilt half axles...
  4. Jan 10, 2014 at 9:32 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I have CVJs on my runner, been on since summer with the silicone boots. They have been holding up great so far, but still limited miles. They definitely have not slipped or leaked grease like the stock did after lifting though.
    Check my build for pics.
  5. Jan 11, 2014 at 7:45 AM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I checked out your build, looks good. Great Pictures!
    Do you know why they don't offer the outer boots?
    I will probably give these a try, but I'd like more feedback...No such thing as to much feedback
  6. Jan 11, 2014 at 6:10 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Thanks!
    I think it's because most of the strain and flex comes on the inner. That is where all the boots that I have seen leak from or bands come loose. CVJ was great to work with, they are local to me so that helped, but even over the phone they were very helpful. Highly recommended.
  7. Jan 11, 2014 at 9:45 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I've used them, and can't see any longevity issues different than a "normal" boot. They aren't any better, and seem to get holes poked in them easier, but don't split...maybe you could try running a leather boot over them like on porches?
  8. Jan 12, 2014 at 5:58 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    What brand did you have, or do you think they all come from the same place regardless (china)? And by holes do you mean from shit on the trail like branches?
  9. Jan 12, 2014 at 6:53 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I think they were Empi? I got them at Kartek, and if anything were probably of German origin but who knows. Yeah, branches, rocks, whatever. I only had that problem on the outers though, so maybe they would make it as inners. I'm running the All-pro "long travel" outers and haven't had a problem with them at all. I have about 30,000 miles on them or so (longer than any other boot lasted me, I'm hard on stuff though).
  10. Jan 12, 2014 at 8:03 AM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    This could answer why CVJ only offers "standard" outer boots.
    I looked at Allpro's website and it appears even though theses are "long travel" boots they recommend them for all lifted applications. I wonder if anyone who's not long travel is running these for outers...
  11. Jan 12, 2014 at 9:10 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Yes, they will fit on any taco. They are a little longer, but they hold tight with the plumbers tape style clamp they use. I use those clamps on all four positions, it makes changing boots much less hassle.
  12. Oct 7, 2015 at 11:16 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Low Range sells these outer LT boots also. They actually fit over the OEM boot and the guy I talked to at Low Range wasn't really keen on them.
    Edit: actually can someone verify this? http://www.lowrangeoffroad.com/yota...ner-long-travel-outer-c-v-boot-and-clamp.html
