Silver07taco rear bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by silver07taco, Feb 4, 2009.
  1. Feb 7, 2009 at 8:23 PM
    #101
    silver07taco
    silver07taco [OP] Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Yea, I rather be safe then sorry on that, But the reat locker comes first:D
  2. Feb 7, 2009 at 8:24 PM
    #102
    SilverSeven
    SilverSeven Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    dude, your bumper is bolted to the frame right?? its wayy beefier than any hitch,, you can just get some fab guy to put a hitch in behind the lisence plate that will pull just as much as factory ho hitch
  3. Feb 7, 2009 at 8:26 PM
    #103
    silver07taco
    COIL
    Maryland
    Yea, If I do that I want it bolted to the frame again come off the bottom of the frame to a hitch box and throught the bumper behind the plate and need ground clearance.
  4. Feb 9, 2009 at 4:01 AM
    #104
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    can the mounting plates be relocated to go "over" the hitch? widened? what i'm thinking is cut mount plates off...move outward...3/8" on either side, get longer bolts, then bolt through the bumper and fac. hitch with longer bolts. this theory may be way off as i'm speculating.
    l l
    l l
  5. Feb 9, 2009 at 12:37 PM
    #105
    silver07taco
    COIL
    Maryland
    The problem isnt the mounting its how much the factory hitch hangs down on the new bumper so Im goin to have a custom one made work work with the new bumper.
  6. Apr 9, 2009 at 7:23 AM
    #106
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I'm looking into getting the same bumper as you, but I need to keep my hitch. Would I be able to use the OEM hitch and just have it be ugly, or would it not work without some welding, drilling, and grinding?
  7. Apr 9, 2009 at 5:16 PM
    #107
    silver07taco
    COIL
    Maryland
    Your goin to have to buy the hitch with the bumper, The stock one hangs down about 2-3 inches from the bottom of the bumper, Its not worth tryin to keep the stock, Pain in the ass cutting and welding it back up.
