SilverGhost Rises
Discussion in '1st Gen. Builds (1995-2004)' started by SilverGhost, Jan 24, 2015.
What’s the next name for this Big Balls Ray?
  1. BlueBallsRay
    11 vote(s)
    22.0%
  2. BlueGhost
    17 vote(s)
    34.0%
  3. You can save 15% by switching to Geico
    12 vote(s)
    24.0%
  4. BBR
    5 vote(s)
    10.0%
  5. BigBlueBallsRay
    5 vote(s)
    10.0%
  1. Jan 11, 2016 at 9:52 AM
    #761
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Those uca's were a f'ing b@&ch! They were wider than the gussets I welded in even with the washer and sleeves. Beat the gussets back a little and sinched down the bolt. Fits snug but moves. Is that ok? Also I can't fit a washer on the gusset side. Thoughts?
    Edit: gusset plate acts as the washer. Don't tighten until the truck is on the ground. It's ok the uca's are stiff. Ah, im a rookie. We're both gonna know all about this stuff.
    Thx
  2. Jan 11, 2016 at 11:51 AM
    #762
    SilverGhost
    SilverGhost [OP] Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Thanks bud and welcome.
    For the TC UCA the gusset side didn't take washers. Now for the Solo kit I have clue. The UCA do fit tight. It's not a big deal. But the TC gussets are designed for the Tc UCA too. All it takes 1/8 wider for it to kick your ass. Hopefully you got them all in.
    j0shu4[QUOTED] likes this.
  3. Jan 11, 2016 at 6:29 PM
    #763
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    My arms are also very tight in the gussets. The arms spread a little when I pull them out, so when I put them back in I put them crooked, then "slide" them into position and it squeezes the arms together. No washers on the gusset side, washers fit tight in the middle against the shock tower
    j0shu4 likes this.
  4. Jan 11, 2016 at 8:00 PM
    #764
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Welcome JD! Thanks for the info and all the help with LT stuff. It's been a while since I picked your brain a couple of yrs back but i'm finally getting it done. :thumbsup:
  5. Jan 11, 2016 at 8:04 PM
    #765
    Cr250jumper
    The moon
    50 shades of tan©
    It looks awesome, I like the 4wd addition and might have to pick your brain about that someday ;)
  6. Jan 11, 2016 at 8:10 PM
    #766
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    Ray I can't even tell you how much his thread motivates and impresses me.
    CO MTN Steve likes this.
  7. Jan 11, 2016 at 8:31 PM
    #767
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Thanks Andy. I appreciate the support. You like a lot others have been a big help with info and support.
  8. Jan 12, 2016 at 4:53 PM
    #768
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Just a feeler. Anyone interested in getting their hands dirty this weekend?
  9. Jan 12, 2016 at 4:57 PM
    #769
    odomandr
    Andy
    Fort Collins, CO
    Ray I will check and see what Rochelle has planned she had mentioned getting away because we have MLK off monday
  10. Jan 12, 2016 at 5:02 PM
    #770
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    If I was still on the front range I'd be over in a heartbeat. What are you knocking out this weekend Ray?
  11. Jan 12, 2016 at 5:11 PM
    #771
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Everything to get running. Brakes, fluid changes, remote resi mounting, bolt on exhaust. Just a bunch of little things. By myself it will take time but with a few extra hands we could get it done quick. I just want to get it running and see how the motor does. I'm dropping the transmission pan now and fixing the leak.
    j0shu4 and odomandr like this.
  12. Jan 13, 2016 at 9:34 AM
    #772
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I should be down to help a bit if needed dude.
    SilverGhost[OP] likes this.
  13. Jan 13, 2016 at 10:29 AM
    #773
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Might could make it Ray. My spare might work for you too.
    PS78 and SilverGhost[OP] like this.
  14. Jan 13, 2016 at 11:12 AM
    #774
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Thanks guys. If you can, cool. If not no biggie.
  15. Jan 13, 2016 at 11:13 AM
    #775
    T-Rex266
    Elon
    What day and time u thinking?
  16. Jan 13, 2016 at 11:31 AM
    #776
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Saturday around 9- 10 or so. After it warms up. I'll be starting when I wake up.
  17. Jan 13, 2016 at 12:39 PM
    #777
    T-Rex266
    Elon
    Dude, you get up like @5am.
  18. Jan 13, 2016 at 1:48 PM
    #778
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yeah..... :D
  19. Jan 13, 2016 at 7:37 PM
    #779
    odomandr
    Andy
    Fort Collins, CO
    Ray, I recall you said you got some hardware from Jims. I was wondering if you have a tap and die set? If not may I suggest it for anything that may be previously used
  20. Jan 13, 2016 at 7:43 PM
    #780
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I already used the hardware I got from Jims. It all worked out. Thanks
    odomandr likes this.
