SilverGhost Rises
Discussion in '1st Gen. Builds (1995-2004)' started by SilverGhost, Jan 24, 2015.
What’s the next name for this Big Balls Ray?
  1. BlueBallsRay
    11 vote(s)
    22.0%
  2. BlueGhost
    17 vote(s)
    34.0%
  3. You can save 15% by switching to Geico
    12 vote(s)
    24.0%
  4. BBR
    5 vote(s)
    10.0%
  5. BigBlueBallsRay
    5 vote(s)
    10.0%
  1. Oct 21, 2016 at 2:31 PM
    #1001
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Some #2 welding or battery cable, that should cover it. Any color. :)
    Personally I think the welding cable is better due to the higher strand count. Has better flex and current carrying characteristics. I bet you know where to get some. If not, ACE hardware carries it in 25 foot lengths.
    Mount that sucker solid is about all I can suggest on the battery.
    Use care in routing the battery cables to avoid chafing, rubber tubing makes an excellent insulator, can be slit down the side and wrapped right over the battery cable. Cheap Garden hose is excellent for this. I'd wrap the entire length if necessary.
  2. Oct 21, 2016 at 2:37 PM
    #1002
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Fricking MacGyver:)
  3. Oct 21, 2016 at 3:28 PM
    #1003
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    without the mullet though.;)
    303tacoma[QUOTED] likes this.
  4. Oct 21, 2016 at 3:45 PM
    #1004
    SilverGhost
    SilverGhost [OP] Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Ok this is another winter project for me. I fond some for a decent price on Amazon. Will I need a breaker switch in the engine bay?
    303tacoma likes this.
  5. Oct 21, 2016 at 3:49 PM
    #1005
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I'm assuming you are relocating it for weight reasons? and not to add a second battery?
    Either way I wouldn't see a need for a breaker. As long as you take care in the wire routing so that there is no chance of a short, then you should be ok. Remember, you are jumping, so think of impact on landing and how that cable will react. If it's sheathed in tubing/garden hose and not pinched anywhere, I would not worry about it. Charging and winching systems are best run direct with no breaker or fusing.
  6. Oct 21, 2016 at 4:00 PM
    #1006
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yeah I'm just relocating because of weight. I have a bigger battery in there now and the weight broke my spot welds on the radiator support when jumping it. I totally get what you mean about the garden hose I do the same thing on my machine at work with the hyd lines. Protects the hoses pretty good.
    Deathbysnusnu[QUOTED] likes this.
  7. Oct 23, 2016 at 9:11 PM
    #1007
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Summit sells kits for battery relocation. Ordered mine from them. Worked well. A breaker is highly recommended in case a wreck or something goes wrong it won't burn ur truck down. I didn't have one but was gonna order one... Did the relocation just before I left for her last mission :pout: never got to get the breaker
    SilverGhost[OP] likes this.
  8. Oct 24, 2016 at 2:35 AM
    #1008
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Ok bud. I'll look into it thanks.
  9. Nov 19, 2016 at 9:54 AM
    #1009
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I picked these up. Adding the Tundra brakes.
    I also have these parts on the way.
    Dalandser, j0shu4, T-Rex266 and 4 others like this.
  10. Nov 19, 2016 at 11:19 AM
    #1010
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Are those the right pads and rotors for the Tundra calipers?
    Edit: just googled it, you got a good price on them too.
  11. Nov 19, 2016 at 11:41 AM
    #1011
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I believe so. I tried cross checking them on google. They come up as the right one. Of corse the pic isn't the actual pic of the item I bought. Plus Amazon always was good to me with replacing wrong items. So I'm not to concerned if I ordered the wrong ones. I also put in Amazon that I was looking for an 05 Tundra and it said it fit. We shall see.
    -40 and Deathbysnusnu[QUOTED] like this.
  12. Nov 26, 2016 at 12:20 PM
    #1012
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Thanks to @-40 for the info. I finally got around to doing the tundra brakes.
    LukeCC, j0shu4, T-Rex266 and 5 others like this.
  13. Nov 26, 2016 at 1:27 PM
    #1013
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Sweet!
  14. Nov 26, 2016 at 2:20 PM
    #1014
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Nice Ray :thumbsup:
  15. Nov 26, 2016 at 2:28 PM
    #1015
    -40
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
    Glad it worked out for you.
  16. Dec 1, 2016 at 3:08 PM
    #1016
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    May ask for those links down the road :spy:
    Not sure if I wanna go with the Amazon package or not. I'd prefer not to have red calipers
  17. Dec 1, 2016 at 3:14 PM
    #1017
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I'm not much of a fan of red either. That's why I went with the Napa ones. I did want to paint them blue but black is fine with me too.
  18. Dec 1, 2016 at 3:16 PM
    #1018
    BYJOSHCOOK
    Josh
    Check Out My Builds
    That's what I was going to do. Depending on if I get a DD prior to ordering this (probably not) I'll paint them blue. But not likely.
  19. Dec 17, 2016 at 11:21 AM
    #1019
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I might as well post a pics of my patches. I have a few more on their way here.
    j0shu4, T-Rex266 and jubei like this.
  20. Dec 29, 2016 at 5:49 AM
    #1020
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    More patches. I think I have 3 more in the mail.
    jubei, T-Rex266 and Gramps like this.
