SilverGhost Rises
Discussion in '1st Gen. Builds (1995-2004)' started by SilverGhost, Jan 24, 2015.
What’s the next name for this Big Balls Ray?
  1. BlueBallsRay
    11 vote(s)
    22.0%
  2. BlueGhost
    17 vote(s)
    34.0%
  3. You can save 15% by switching to Geico
    12 vote(s)
    24.0%
  4. BBR
    5 vote(s)
    10.0%
  5. BigBlueBallsRay
    5 vote(s)
    10.0%
  1. Feb 21, 2017 at 8:06 AM
    #1241
    SilverGhost
    SilverGhost [OP] Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    It's an in-tank.
    Another thing about the sending unit can I use a jaz sending unit with new gauge. Or do I have to use a Toyota one? I don't care about the factory gauge wiring or not if I have another one. I just don't know if that would cause issues with the ECU....
  2. Feb 21, 2017 at 8:26 AM
    #1242
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
  3. Feb 21, 2017 at 8:26 AM
    #1243
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Depends, most aftermarket fuel cells run a "American" style sending unit for the gauge. The shit deal is they run the resistance backwards comapered to Toyota. Your gauge would be E=enough, F=fucked
  4. Feb 21, 2017 at 8:27 AM
    #1244
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Make a new filler plate to use the stock parts. You may need to extend it to match the new height of the cell. Fuel gauge works, return is still there, and can add high LPH pump at the same time even without larger injectors or forced induction. Been there done that, easier to reuse stockish parts if your are going to keep the dash and gauge cluster.
    IMO get a Harmon or Fuel safe. Jaz are cheap and you get what you pay for.
    http://www.harmonracingcells.com/sloped-bottomtruck.html
    If you're still sold on the jaz, pull the foam before you fuel it. The ethanol will break down the foam in a year or less and clog your filters.
    And 3 link vs 4 link:
    There is no difference if the geometry is setup the same, One upper joint on the axle vs 2.
    Did you buy a DD yet?
    jubei likes this.
  5. Feb 21, 2017 at 8:27 AM
    #1245
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
  6. Feb 21, 2017 at 8:35 AM
    #1246
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yeah sold on the jeepspeed because of the shape. Ok I'll remove the foam and replace with some balls I seen not to long ago. I'll have to look them up again.
  7. Feb 21, 2017 at 9:36 AM
    #1247
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The OEM pump is fine for even some boost so up to you really. If you get an aftermarket one, do NOT get a walbro. Fuckin loud bitch of a pump. AEM or Denso is the way to go there.
  8. Feb 21, 2017 at 10:12 AM
    #1248
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    @thefatkid one more question. Does the charcoal canister need to be mounted horizontal the way it is now or can I also mount it vertical?
  9. Feb 21, 2017 at 10:13 AM
    #1249
    Blackdawg
    Monte
    Wyoming/St. Louis
    why would you keep that at this point? Or does CO have emissions?
  10. Feb 21, 2017 at 10:18 AM
    #1250
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yes. The truck is still a DD. I could get away with links and fuel cell but the truck needs to still pass emissions.
    Dalandser likes this.
  11. Feb 21, 2017 at 10:22 AM
    #1251
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Yesssssssssss.
  12. Feb 21, 2017 at 10:44 AM
    #1252
    Blackdawg
    Monte
    Wyoming/St. Louis
    damn Co..lol
  13. Feb 21, 2017 at 10:55 AM
    #1253
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    FTFY
    I have no emissions testing.
  14. Feb 21, 2017 at 10:59 AM
    #1254
    Blackdawg
    Monte
    Wyoming/St. Louis
    If i have learned anything from you...
    Its not to live on the front range
  15. Feb 21, 2017 at 11:01 AM
    #1255
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    And yet the majority of us live here. It's a lot like SoCal these days. I think the OP is from there as well.
    jubei likes this.
  16. Feb 21, 2017 at 11:02 AM
    #1256
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea i used to drive through there on the way to St louis twice a year. Place has exploded
    Deathbysnusnu[QUOTED] likes this.
  17. Feb 21, 2017 at 11:20 AM
    #1257
    thefatkid
    Brian
    Colorado
    2004 thingy
    It could mess with valve operation. Though, like anything, try it and see.
  18. Feb 21, 2017 at 12:10 PM
    #1258
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Make sure they're big enough.
    Gotta stick with the theme. :D
  19. Feb 21, 2017 at 12:15 PM
    #1259
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Wiffle balls?
    Not needed, if you keep the pump/ fuel level bracket you will be fine.
    Could run this to help with the pickup.
    https://www.holley.com/products/fuel_systems/hydramat/
  20. Feb 21, 2017 at 12:16 PM
    #1260
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    No biggie. I'll make it work.
