SilverGhost Rises
Discussion in '1st Gen. Builds (1995-2004)' started by SilverGhost, Jan 24, 2015.
What’s the next name for this Big Balls Ray?
  1. BlueBallsRay
    11 vote(s)
    22.0%
  2. BlueGhost
    17 vote(s)
    34.0%
  3. You can save 15% by switching to Geico
    12 vote(s)
    24.0%
  4. BBR
    5 vote(s)
    10.0%
  5. BigBlueBallsRay
    5 vote(s)
    10.0%
  1. Mar 3, 2017 at 9:14 AM
    #1361
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    That top tube looks bad ass dude!
    ChadsPride likes this.
  2. Mar 3, 2017 at 11:31 AM
    #1362
    SilverGhost
    SilverGhost [OP] Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I will once it's painted.
    Thanks buddy.
  3. Mar 3, 2017 at 12:49 PM
    #1363
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    First patch! Thanks again, Ray!
    :headbang:
  4. Mar 3, 2017 at 1:02 PM
    #1364
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    @SilverGhost #BBR popping everyone's patch cherry
  5. Mar 3, 2017 at 1:23 PM
    #1365
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Your welcome buddy.
  6. Mar 3, 2017 at 4:17 PM
    #1366
    jubei
    NoCo
    Stuff. Also things.
    For sure!
    He was very gentle.
  7. Mar 3, 2017 at 4:49 PM
    #1367
    j0shu4
    :rofl:
    ChadsPride and SilverGhost[OP] like this.
  8. Mar 4, 2017 at 6:40 AM
    #1368
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Done for now.
    T-Rex266, alee891, Gramps and 9 others like this.
  9. Mar 4, 2017 at 6:46 AM
    #1369
    jubei
    NoCo
    Stuff. Also things.
    Turned out great, Ray!
  10. Mar 4, 2017 at 6:53 AM
    #1370
    cynicalrider
    cynicalrider #NFG
    Jersey
    :drool: Awesome work as always.
  11. Mar 4, 2017 at 6:14 PM
    #1371
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
  12. Mar 4, 2017 at 6:17 PM
    #1372
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  13. Mar 4, 2017 at 6:42 PM
    #1373
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Good just wanted to double check before I walk gauntlet trying to convince Barb to let me get it.
  14. Mar 4, 2017 at 7:41 PM
    #1374
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
  15. Mar 4, 2017 at 7:51 PM
    #1375
    Blackdawg
    Monte
    Wyoming/St. Louis
    All the offroad hard core folks run ford 9"s.
    A landcrusier 9.5 or tundra 10.5 wouldn't be bad though.
  16. Mar 5, 2017 at 5:28 AM
    #1376
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Need to pump my brakes for a sec. It say it's a 31 spline shaft and the tundra is a 30 spline. Isn't the hubs machined to the shafts? Wouldn't I have to replace the shafts too to switch the hubs?
  17. Mar 5, 2017 at 5:37 AM
    #1377
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    No hubs to swap on a semi float 9".
    Currie, moser, G2, ect sells complete shafts to match that axle and your bolt pattern.
    Imo not a great buy at that price. The case isn't anything special, same with the housing. As those are the only parts that will be reused. That should be a big bearing housing, got to measure the bolt pattern to confirm.
    Ray, build your Tundra axle for now as your third drops in. Will work with links unless your wanting to go wider.
  18. Mar 5, 2017 at 6:08 AM
    #1378
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Ok. I'm already going wider with the tundra housing. That housing is close to the width I'm looking for. Plus adding a 9" to the rear. I really don't much about rear ends that's why I threw it up here. To get opinions.
    As of now I only have a tundra housing and my 8.4 diff. I'll would still end up spending 300-350 for complete used OEM axle shafts for the rear from Jim's. Plus whatever for little odds and ends. I won't have to regear.
    So I would have to see if @thefatkid could do a 9" regear and convert it to a posi from a non posi too. Also get a extended yoke plus all the brakes parts. It adds up. I just wondering if the 9" would be worth the money, time and effort.....
    I just want to make the smart choice. Maybe sticking with my current route might be the smart choice to save the cash that can go towards shocks or parts for links.... decisions.....
  19. Mar 5, 2017 at 6:21 AM
    #1379
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Trail gear make chromoly replacement shafts?
    You'll spend more than that for 31 spline 6 lug 9" shafts to go in that Bronco housing. Then the re gear, arb locker, bearings, brakes. 9" is worth it but IMO not that one. Stay the course with the Tundra and save up and go with a fab housing, nodular third, 35 spline 9" later.
  20. Mar 5, 2017 at 7:04 AM
    #1380
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Ok. Good advice and good points. I'll do that. I'll stay with the tundra housing and setup.
