SilverGhost Rises
Discussion in '1st Gen. Builds (1995-2004)' started by SilverGhost, Jan 24, 2015.
What’s the next name for this Big Balls Ray?
  1. BlueBallsRay
    11 vote(s)
    22.0%
  2. BlueGhost
    17 vote(s)
    34.0%
  3. You can save 15% by switching to Geico
    12 vote(s)
    24.0%
  4. BBR
    5 vote(s)
    10.0%
  5. BigBlueBallsRay
    5 vote(s)
    10.0%
  1. Feb 13, 2018 at 5:18 AM
    #1721
    SilverGhost
    SilverGhost [OP] Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Yeah check out 1st gen what have you done to your taco today thread. Some one posted your model taillights there.
    BYJOSHCOOK[QUOTED] likes this.
  2. Feb 18, 2018 at 10:39 AM
    #1722
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I’m going to relocate my front shock resi. So I made new mounts and welded them to the coil bucket gusset. This location is so much better then on the frame. I never liked them on the frame because they look like a target for something to hit them. Good thing Tim isn’t to far from me. He’s going to get new hoses, oil change and new valving.
    Another thing off the list is relocating the cab fuse box. It was in the way of the A pillar tube. So I made a bolt on bracket to push it back 4”- 5”. Now it’s completely out of the way. Time to start designing the A pillar and engine cage tie in. This is going to be slow going.
  3. Feb 18, 2018 at 10:52 AM
    #1723
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    I hope you can still get your UCA bolt out
  4. Feb 18, 2018 at 12:06 PM
    #1724
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yup. I just need to remove the resi to do that. Two hose clamps is the only thing holding the resi.
    teamhypoxia[QUOTED] likes this.
  5. Feb 18, 2018 at 2:17 PM
    #1725
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Some more stuff done for now. I got one pipe in. Interesting how it wants to sit in there. Driver side has a greater angle then the passenger side. Plus it sits better with the tube at a slight angled down instead of straight horizontal across the dash because of the cluster wires. I also made a temporary support for the passenger side dash bar and cut off everything that was in the way of where the tube is going to go. I’m planing on putting a flat plate on the end of where I cut it and placing a plate on the cage so I can bolt the bash bar to the cage. All this is going to happen on the driver side too.
  6. Feb 18, 2018 at 5:24 PM
    #1726
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    Ray, you going to put a grab handle on the dash? something like the jeep has on the passenger side is what im thinking
  7. Feb 18, 2018 at 6:29 PM
    #1727
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    No, this is a hands in the air ride :D IF you need something to grab you'll have a 5 point harness to hang onto. I will put a couple of handles on the cage to replace the stock ones.
    Dalandser and odomandr[QUOTED] like this.
  8. Feb 18, 2018 at 7:04 PM
    #1728
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Nice work going on in here :thumbsup:
    SilverGhost[OP] likes this.
  9. Feb 18, 2018 at 7:45 PM
    #1729
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Thanks James. I'm hoping on getting more work done through the week.
  10. Feb 18, 2018 at 8:37 PM
    #1730
    RockiesTaco
    RockiesTaco Well-Known Member
    Bart
    PHX
    2021 JLUR
    Great work Ray! I’m super impressed with your dedication and ability to take an idea and make it reality! Top notch man!
  11. Feb 18, 2018 at 9:32 PM
    #1731
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Thanks Bud. Welcome.
    RockiesTaco[QUOTED] likes this.
  12. Feb 18, 2018 at 10:12 PM
    #1732
    RockiesTaco
    Bart
    PHX
    2021 JLUR
    Oh I’ve been here a long time. I’m a professional lurker...:burp:
  13. Feb 19, 2018 at 8:17 AM
    #1733
    cynicalrider
    cynicalrider #NFG
    Jersey
    How are you bending the PVC? Using a bender and heat? Or will just a bender do it? I always love your PVC method for mock ups.
  14. Feb 19, 2018 at 9:26 AM
    #1734
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I used to just use a heat gun and heat it. But it took forever because the heat escaped. So I built a hot box to heat it. It drop the time in half. It is just a 1/2 plywood box notched out for the pipe and lined with foil paper. I also just made this larger angle guide out of a meter stick with a bolt and wing nut. I set that angle to the pipe. Hold it with gloves and just let the pipe cool.
    Dalandser, RockiesTaco and BYJOSHCOOK like this.
  15. Feb 19, 2018 at 4:12 PM
    #1735
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Got some more work done. Doesn’t seem like a lot but it takes a lot of time bending and re-bending pvc over and over again to get it right. Good thing about pvc you can just re heat it to adjust it to how you need it. The pic with the blue circle is a bend that I got wrong and had to redo it.
    Dalandser, Cid, Deathbysnusnu and 3 others like this.
  16. Feb 19, 2018 at 5:18 PM
    #1736
    odomandr
    Andy
    Fort Collins, CO
    Damn ray that looks really good.
  17. Feb 19, 2018 at 5:38 PM
    #1737
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Thanks Andy. The tricky part is going to be welding it all. Brain is going a million miles an hr now. :D
  18. Feb 20, 2018 at 5:09 AM
    #1738
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Sweet!
  19. Feb 20, 2018 at 7:29 AM
    #1739
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    @Cr250jumper im noticing that my B pillar tube is going to land right over the trailing arm mount. Does the B pillar need to be welded to the frame? I would think so. Or can I run it to the floor tube in the cab?
  20. Feb 20, 2018 at 7:37 AM
    #1740
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    How high will the link mount be? Mine lands at the same spot too but the cage lands even with the top of the frame so still plenty of room for the link mount, can see here on the left side. But yeah it should land to the frame somehow
    Dalandser likes this.
