SilverGhost Rises
Discussion in '1st Gen. Builds (1995-2004)' started by SilverGhost, Jan 24, 2015.
What’s the next name for this Big Balls Ray?
  1. BlueBallsRay
    11 vote(s)
    22.0%
  2. BlueGhost
    17 vote(s)
    34.0%
  3. You can save 15% by switching to Geico
    12 vote(s)
    24.0%
  4. BBR
    5 vote(s)
    10.0%
  5. BigBlueBallsRay
    5 vote(s)
    10.0%
  1. Feb 20, 2018 at 7:43 AM
    #1741
    SilverGhost
    SilverGhost [OP] Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Ok I see what you did. The bolt hole for the lower is going to land at 5/8” below frame. But I see how you notched out for the cab cage mount. I’ll do the same when I build the link mounts. Thanks. :thumbsup:
  2. Feb 20, 2018 at 7:49 AM
    #1742
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Yeah I built mine and tehn realized I would have to notch it, but I think being all tied in ended up pretty good
  3. Feb 20, 2018 at 10:09 AM
    #1743
    cynicalrider
    cynicalrider #NFG
    Jersey
    Haha love this dude. Really perfected the process of PVC mock ups. The cage is coming out great!
  4. Feb 20, 2018 at 2:28 PM
    #1744
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    @Cr250jumper and @MadTaco461 thoughts on how I’m thinking about setting up the B pillar. Anything I should consider or change? Blue tape possible tube.
    -40 likes this.
  5. Feb 20, 2018 at 2:48 PM
    #1745
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Dalandser likes this.
  6. Feb 20, 2018 at 3:01 PM
    #1746
    MadTaco461
    CA
    Kinda stock
  7. Feb 20, 2018 at 3:07 PM
    #1747
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    I'd go with an X on the top portion.
  8. Feb 20, 2018 at 3:11 PM
    #1748
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    @MadTaco461 ok thanks I’ll look into those builds. Oh and I’m not putting seats in the back seat. It will be tool boxes.
    One more question for both of you. @Cr250jumper Should I go larger on the corner gussets?
  9. Feb 20, 2018 at 3:16 PM
    #1749
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    That’s what I’m going to do in the C pillar (something like this *) but I don’t want all those tubes in the B pillar. I’ve seen a truck like this. I didn’t mind adding the extra two tubes straight down to help the ones angled to the corners.
  10. Feb 20, 2018 at 4:13 PM
    #1750
    MadTaco461
    CA
    Kinda stock
    Those gussets are plenty big.
    SilverGhost[OP] likes this.
  11. Feb 21, 2018 at 7:11 AM
    #1751
    Cr250jumper
    The moon
    50 shades of tan©
    Corner gussets look good. But I agree with flipping to "V" or do an "X" so the top corner of the B pillar is supported. Otherwise nothing is keeping that section from pushing towards your head. The "A" does good for supporting the center of the roof but there is no support for a side impact to the B pillar
  12. Feb 23, 2018 at 3:21 PM
    #1752
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Big thanks to @Cr250jumper , @MadTaco461 and @RedManRocket for your input. I think this will do. I’ve seen on some trucks with the center of the B pillar gusseted. Should I do the same? On the upper parts of the B pillar I did follow the same bends of the bar across behind the seats because need space for seats headrest. But the lowers are straight.
  13. Feb 23, 2018 at 3:47 PM
    #1753
    RedManRocket
    Red
    2002 Double Cab LT
    Now that's a cage
  14. Feb 23, 2018 at 4:27 PM
    #1754
    MadTaco461
    CA
    Kinda stock
    Looking good. You only need a gusset where you aren't going to have a triangle. It's usually along the window and door jam sections.
    Prayn4surf and SilverGhost[OP] like this.
  15. Feb 23, 2018 at 4:33 PM
    #1755
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    I think you need to paint all your tube work white, then airbrush the text from PVC onto it when you're all done. lol
  16. Feb 23, 2018 at 5:28 PM
    #1756
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    o_O:rofl: Tacky.
    ebbs15[QUOTED] likes this.
  17. Feb 23, 2018 at 10:18 PM
    #1757
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    A little bit of eye candy. Wasn’t going to share these but I figure what the hell. This is going to be the new seats for the truck. I just might have to order one before I build the cage to make sure it will fit right before I weld in the cage.
  18. Feb 23, 2018 at 10:29 PM
    #1758
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I say you repurpose the pvc cage into a tent that can protect you if you somehow roll down a hill in the middle of the night.
    ebbs15 and SilverGhost[OP] like this.
  19. Feb 23, 2018 at 10:32 PM
    #1759
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I should take it to the off road swap meet and sell it :p
    Dalandser[QUOTED] likes this.
  20. Feb 23, 2018 at 10:33 PM
    #1760
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Considering the time it would save someone it would be a good idea! Just label all the parts!
