SilverSeven's build up
Discussion in '2nd Gen. Builds (2005-2015)' started by SilverSeven, Dec 1, 2008.
  1. Sep 1, 2009 at 7:32 AM
    #421
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    well if/when i ever get around to it... i think i'll use a D44 out of a late 70's f-250. then pull off the knuckles and throw on a set of chevy 1/2 ton flat top knuckles. this would put the WMS-WMS at about 1" wider than the factory rear. throw a set of 1/2" wheel spacers on the rear and you've got matching widths on the axles. plus there are plenty of readily avaliable parts for these axles and plenty of people have done simlar swaps putting chevy outters on ford axles so its nothing new. i just did alot of research trying to find a good axle setup that had the right width and thats what i came up with.
  2. Sep 1, 2009 at 7:35 AM
    #422
    SilverSeven
    SilverSeven [OP] Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    nice, thats pretty much what i am doing Im not exactly sure where my wms will come out, but i remember reading taht it will be about 2" wider than stock
  3. Sep 1, 2009 at 7:38 AM
    #423
    Fire931
    VA
    00 4Runner
    yea the f-250 axle is a little wider than stock. but its an 8 lug also. once you pull those knuckles and throw on some chevy 6 lug knuckles it narrows it up just a touch and puts it just about right. plus the beauty of this is that you can run most all standard parts instead of having to have custom axles cut and whatnot.
    if/when i ever do it i would never run anything larger than a 35 or 36 tire so there is no need to go with anything larger such as a D60. plus with that tire size the toyota rear should hold up just fine.
  4. Sep 1, 2009 at 7:40 AM
    #424
    SilverSeven
    Jordon
    South Jurzee
    true, i am going 37" but i think i will still be ok with the right gears and inners. I also plan on beefing up my rear with longs
  5. Sep 1, 2009 at 7:41 AM
    #425
    Fire931
    VA
    00 4Runner
    yea well living in VA they are really strict on height laws and whatnot... if i went any larger the truck would be to tall to legally drive on the street here....
  6. Sep 1, 2009 at 7:49 AM
    #426
    SilverSeven
    Jordon
    South Jurzee
    currently i need reccomendations spindles, brakes
  7. Sep 1, 2009 at 8:25 AM
    #427
    SilverSeven
    Jordon
    South Jurzee
    what are the parts on the end of the axle that the knuckle bolts to called? and where can i buy them?
    edit: found them.
  8. Sep 1, 2009 at 10:46 AM
    #428
    SilverSeven
    Jordon
    South Jurzee
    got a few more things, decided im going to re-tube my cast 44. Dont worry i will still be at about $2500 less than a diamond.
  9. Sep 1, 2009 at 12:39 PM
    #429
    Fire931
    VA
    00 4Runner
    if you retube it just make sure you do it back to a stock length. that way you dont have to custom order axles for it.
  10. Sep 1, 2009 at 3:35 PM
    #430
    SilverSeven
    Jordon
    South Jurzee
    True. Ill try and find the widest d44 and go with that
  11. Sep 2, 2009 at 6:23 AM
    #431
    SilverSeven
    Jordon
    South Jurzee
    question,
    I was contemplating today,
    scary thought yes,
    Can i take all my d44 outer stuff, and get a diamond 8" housing and mate all my d44 outer stuff to the 8" housing?
    obviously i would need to match OD on tubing and also get the housing with no ends.
    anything flawed with this?
  12. Sep 2, 2009 at 6:24 AM
    #432
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Just looking around. Damn looks like actual building going on in here! My build thread sucks in comparison.
  13. Sep 2, 2009 at 6:38 AM
    #433
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    yes, But your is much more spectator friendly. :)
  14. Sep 2, 2009 at 6:55 AM
    #434
    Fire931
    VA
    00 4Runner
    yes you can do this. they have the option of building them this way from the start also... only thing with this is you are starting to look at having custom axles shafts made then.
  15. Sep 2, 2009 at 7:04 AM
    #435
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    haha what build? mines kinda dead, I need some ideas, or something maybe people would like to see on my truck?;)
  16. Sep 2, 2009 at 8:40 AM
    #436
    SilverSeven
    Jordon
    South Jurzee
    everything just changed axle wise. cancelled the order for all parts for D44, except the reid racing knuckles, they already shipped :frusty:
    I orderd a Diamond 8" set up... so far just will be getting the housing and complete outers for mock-up purposes, then will be getting all the rest once the SAS is complete.
    I am way happier with this, yes it will cost me 2000 more dollars, but i will be 5000 times happier with 2 toyota elocked diffs and all that toyota sex under me.
    If you are wondering how my radius arms will work now, I was able to find weld on wedges, so nothing is changing there.
  17. Sep 2, 2009 at 10:54 AM
    #437
    Fire931
    VA
    00 4Runner
    and what spawned this decision?
  18. Sep 2, 2009 at 11:02 AM
    #438
    SilverSeven
    Jordon
    South Jurzee
    i opened up exel and put all the D44 costs in a column, and then compared it to that of the toy diamond, the difference was not enough to go with the 44 over the diamond. There are too many benefits with diamond, 8" elock diff, 3rd member setup, 30 spline longs are a lot stronger than d44 stuff, diamond housing are SWEET.
    the cost diff was a little over $1000 when i put an eaton elocker in the d44 and the retube.
    to me, its worth an extra $1000 to have all that stuff, especially the elocked toyota 3rd, and the diamond housing
    I was going to just put my chevy outers on an 8" diamond open end housing, but after a little reading, it was clear that it would be a waste of time
  19. Sep 2, 2009 at 11:17 AM
    #439
    PrezidentRedz
    Redz
    Owings, MD
    Keep it toyota baby! nice!
  20. Sep 2, 2009 at 11:18 AM
    #440
    Rippin508
    Rippin508 Member
    Awesome build thread SilverSeven.
