similar wheel to the 51 series that will fit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nikpinet, Nov 19, 2015.
  1. Nov 19, 2015 at 2:26 PM
    nikpinet
    nikpinet [OP] New Member
    nik
    2002 taco
    stock (for now)
    Hey guys. I'm new here. Recently bought a 2002 taco. Looking into buying new wheels/tires/leveling kit. I've done quite a bit of research over the last few months and finally decided on what I want. Going up 2.5" in the front and 1" in the back with 32's. For the wheels, my local tire shop ordered a 15x8 Pro comp 51 series rim for test fitting, and as you all know it doesn't fit. Hits the caliper. Now, if I run a 3/4 spacer on a wheel with a BS of 3.75, the wheel is going to stick out a little too much. My question is, does anyone know of a brand who makes a wheel with the same design as the 51 series that will fit my truck? I've done a lot of research with no good results. My buddy has a set of 97 series on his first gen, but I don't like the look as much as the 51's. Sorry for the noob thread, just looking for some input.
    Thanks guys,
    -Nik
  2. Nov 30, 2015 at 7:45 AM
    Master96Yota
    Master96Yota Active Member
    1996 red single cab rwd tacoma
    Stock:(...for now
    Trailmaster suspension makes a set. I just bought some for my 96 and they fit fine. Didnt put tires on them yet just test fitted the rim.
  3. Nov 30, 2015 at 9:15 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I think any of the stamped steel wheels will fit without a small spacer. Regardless of the backspacing, it's still stamped steel. It's not like a forged or cast wheel where there's a sharp shoulder. The stamped wheels need to be smoother at that point or they'll be weak.
