Simple Clutch Mod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dillypoop, Feb 4, 2018.
  1. Feb 4, 2018 at 5:46 PM
    #61
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  2. Feb 4, 2018 at 6:13 PM
    #62
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Good point. I have never bleed a clutch, why would this method not work as well for bleeding a clutch?
  3. Feb 4, 2018 at 6:44 PM
    #63
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Because typically you are bleeding the brake calipers (slaves) and clutch masters. It is really easy to loose system pressure with a slight screw up on the clutch master side.
  4. Feb 4, 2018 at 7:22 PM
    #64
    tonelover
    tonelover Well-Known Member
    2018 Silver Tacoma TRD Sport
  5. Feb 4, 2018 at 7:26 PM
    #65
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    This threads got legs...good info, let's keep it updated :thumbsup:
    shakerhood, Tacowin1013 and tonered like this.
  6. Feb 4, 2018 at 7:27 PM
    #66
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Worse case call your dealer and tell them wtf it popped off?? Lol
  7. Feb 4, 2018 at 7:29 PM
    #67
    TeecoTaco
    SW Ontario
    K, cide' s the fact that it was started by a guy named @Dillypoop ...
  8. Feb 5, 2018 at 5:10 AM
    #68
    gearcruncher
    Canadain bumper technician
    subd . I am in for the lateral movement of the pedal ???
  9. Feb 5, 2018 at 5:47 AM
    #69
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Ha!
    I'll make sure I don't mark it up when I hulk rage all over it with pliers! :anonymous:
  10. Feb 5, 2018 at 5:59 AM
    #70
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    tonered likes this.
  11. Feb 5, 2018 at 10:10 AM
    #71
    Tacowin1013
    But seriously it works they really can't prove it was you that did damage unless it was after market parts. Even so it's not worth their time to prove so
  12. Feb 5, 2018 at 12:04 PM
    #72
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    I have thought about ditching this spring. Makes the pedal travel feel goofy and hard to judge. And I have driven LOTS of 5speeds over the years. This one is the worst of them. Between this and the throttle by wire, even after 30k miles I still screw up shifts sometimes.
  13. Feb 5, 2018 at 12:47 PM
    #73
    Tacos in Gensokyo
    Tacos in Gensokyo Bohemian Archive in Japanese Red
    2017 SR 4cyl MT SSM
    Rokblokz Mudflaps, 2015 TRD Pro Suspension
    Worked fine for me, or rather, is no worse than stock, in cold weather. Hardest part is somehow squeezing yourself under the dash. That sucked.
  14. Feb 5, 2018 at 1:26 PM
    #74
    MOC221_
    Frank
    Thanks for letting us know dude.. that's good news. So how do you like the clutch feel now (the grab point)?
    I did notice you're running an SR 4 Cyl, which could mean your clutch hydraulic circuit shares fluid with the brake master cylinder?
    All I'm saying is the cold weather performance after removing the spring MAY be different for those of us that have the divorced system with the fluid resevoir on the fender. Its SUPER slow coming off the firewall the first few tries when it's colder than about -10C. I'm still thinking I'm gonna pull the damn thing....
    supralee likes this.
  15. Feb 5, 2018 at 1:30 PM
    #75
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just an FYI, my V6 Sport does not have a separate clutch reservoir. It might only be the MT ORs and Pros?
  16. Feb 5, 2018 at 1:31 PM
    #76
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    It's still the same clutch, but it feels like the 'wandering' engagement point has finally settled down. It's predictable now. Before, the point in travel where the clutch engaged seemed to move around...possibly because of the spring. The clutch is easier to time with the throttle, if that makes sense.
    I need to look under the hood again to see if I have a separate clutch fluid container. Also, I want to try and put the spring back in just so I'm sure I can do so. But it's still like 25 out right now, so working up the motivation to contort under that dash is hard.
    MOC221_[QUOTED], su.b.rat and tonered like this.
  17. Feb 5, 2018 at 1:35 PM
    #77
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I believe that is the case, with ATRAC on the OR and Pro, must not be able to share duty with the clutch.
    MOC221_ and tonered[QUOTED] like this.
  18. Feb 5, 2018 at 4:09 PM
    #78
    Ares32
    Ares32 Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    This would be great news, hate this god damn clutch pedal feel. If no spring feels good in the cold you'll be my hero OP!
    MOC221_ likes this.
  19. Feb 5, 2018 at 5:25 PM
    #79
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am sorry to say, but this clutch spring mod is the first one that I undid.
    It just didn't work for me, only made the clutch heavier, and didn't give me any more feel.
    I'm not dissing @Dillypoop . It was just no bueno for me. I'm looking forward to an accumulator delete though.
    For anyone trying to reinstall the spring, wrap two strong zipties on the arms and compress it as much as you can out of the Taco. Then push the clutch in the whole way. It will drop right in.
    Again, my apologies.
    BTW, I agree that the clock spring is stupidly progressive. A linear spring should have been used there.
  20. Feb 5, 2018 at 5:31 PM
    #80
    su.b.rat
    su.b.rat broken truck
    thanks for that. and again, thanks to @Dillypoop for speaking up. I'll look to try this once it's warm out.
    @tonered do you have any of the skills to work up a mod like you're talking about, accumulator delete or somesuch? there is so much room for improvement, but messing with hydraulics is like the worst idea ever for me. obviously.
    tonered[QUOTED] likes this.
