Simple level success!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wahoobie, Nov 12, 2019.
  1. Nov 12, 2019 at 5:36 AM
    wahoobie
    wahoobie [OP] TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    If you are looking to do a mild level to bring up the front and are a budget diy-er please read on...
    I have been wanting to level out the rig a little since I picked it up last year. My stock rake was just under 2" which I think is about the norm. After some research I ended up installing front spacers: 1/4" Passenger and 1/2" Drivers from @HeadStrong Off-Road (quality product!)
    Final numbers with driver in seat and 3/4 tank gas:
    LF 35-7/8
    RF 35-7/8
    LR 36
    RR 36-1/8 -- i imagine this is because of the gas tank but of course these numbers will change with fill level and passenger load. I think it came out great for the avg load though.
    Pros:
    - cheap until I decide to put in new struts down the road.
    - I can see it....and I like it. Type-A FTW!
    Cons:
    - compressing the spring sucked
    - may need to have alignment checked but marked and returned cam bolts and test drive was a-ok.
    - The drivers side studs needed to be extended so I purchased those as well, hence the need to deal with the spring compression.
    If you don't plan to make any major front end changes this might be an option for you. I like to work on things and this was a new venture so I enjoyed the work and the outcome. I would do it again.
    Cheers!
    CPS-65 and HeadStrong Off-Road like this.
  2. Nov 12, 2019 at 5:40 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Marie @HeadStrong Off-Road really explains it well. I inquired about a 1/2" spacer lift that would give you 1" total lift. You pretty well did the same thing, except for the Taco lean!
    Pics???????
    HeadStrong Off-Road likes this.
  3. Nov 12, 2019 at 5:49 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Also wonder how many people adjust their headlights after a level/lift
    Big tall dave likes this.
  4. Nov 12, 2019 at 5:55 AM
    wahoobie
    chris
    Suffolk, VA
    It's raining but I can get a picture when it breaks. I should check the headlights (and fogs) though minor it's a great thought!
  5. Nov 12, 2019 at 7:05 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Not sure why you would need to touch the cam bolts to remove the strut assembly.
  6. Nov 12, 2019 at 7:19 AM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    I'm on 2.5" lift and I still think my headlight shine too low. Toyota aims them too low to begin with.
    71tattooguy likes this.
  7. Nov 12, 2019 at 7:21 AM
    Shellshock
    Iowa
    im going with nearly zero based on how often I get blinded on road by lifted trucks
    wahoobie[OP] and Tocamo[QUOTED] like this.
  8. Nov 13, 2019 at 10:11 AM
    wahoobie
    chris
    Suffolk, VA
    Here's the outcome
    Deacon Blues and Tocamo like this.
  9. Nov 21, 2019 at 10:45 AM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    That is a great way to lift and trim the truck. I see quite a bit of people going with this especially on the pro's just to level the truck out some while not affecting the ride and the wallet. :D
    wahoobie[QUOTED][OP] likes this.
