Simple performance upgrades
Discussion in '1st Gen. Tacomas (1995-2004)' started by luison, Mar 13, 2013.
  1. Mar 13, 2013 at 8:08 PM
    luison
    luison [OP] Member
    2004 Single Cab 2.4
    I have a 2004 Base Tacoma 2.4.. If I need a lil better performance what should I start with.. What do you guys have?? Can I see some pictures? Can anyone help out please.
  2. Mar 13, 2013 at 8:12 PM
    Trusso24
    Trusso24 Well-Known Member
    Tony
    San Luis Obispo
    99 Prerunner XCab
    Fox Coilovers Blacked Out Debadged
    Lets just say Toyotas are for reliability/dependability, not so much performance. They can perform in the manner that you'll pretty much always make it home. Since yours is the 5 lug your not doing heavy trail ride, I would upgrade your suspension, maybe look into the Supercharger if your getting serious? Search through the 5 lug section. This is just my .02 cents.
    I consider always making it home an excellent performance. That's me though.
  3. Mar 13, 2013 at 8:13 PM
    Trusso24
    Tony
    San Luis Obispo
    99 Prerunner XCab
    Oh, also, I'm not too sure but since yours is the 5 lug and your not seeing to much dust, or mud, etc, the deck plate mod for minimal if any HP and increase sound and throttle. Anyone else can chime in with their opinion.
  4. Mar 13, 2013 at 8:38 PM
    luison
    luison [OP] Member
    2004 Single Cab 2.4
    thanks I think your absolutely right my truck is very reliable and thats great.. I might just keep it stock for reliability and that works for me for right now
  5. Mar 13, 2013 at 11:35 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Only things you can do are
    Deck plate mod
    Maybe new muffler.
    But Toyota did a great job optimizing the performance already. Only other option is TRD supercharger and URD add ons. Or custom turbo. Neither are cheap. But they do give a big boost in performance.
    But that's it.
  6. Mar 14, 2013 at 1:21 AM
    luison
    luison [OP] Member
    2004 Single Cab 2.4
    Im interested in the Deck Plate Mod.. Can you give me more info?? Pictures or just an explanation of what that consist of??
  7. Mar 14, 2013 at 1:28 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  8. Mar 14, 2013 at 1:42 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Lightweight fly wheel,
    new more powerful clutch,
    Deck plate,
    LCEngineering or Doug Thorly Headers,
    Magnaflow 18 inch oval 2.25 in and out muffer welded to stock piping,
    URD or LCengineering short shift kit for 5 speeds only,
    New stiffer front and rear shocks and possibly mild lowering springs,
    keeping tires at proper pressure,
    Steel braided brake lines for better stopping power,
    grease all of your zerk fittings and make sure all of your gear oil is clean,
    if needed replace your O2 sensors and TPS as they tend to go bad over time and can cause a lack in performance and mileage.
  9. Mar 15, 2013 at 8:04 PM
    pinktaco808
    pinktaco808 Hot Steppa
    srs..............................
  10. Apr 25, 2013 at 8:42 AM
    Huntr Pat
    Huntr Pat Green Taco
    Emmett*Idaho
    99 2.7 xtra cab
    K&N,Warn winch w/combo system,3"Revtek bilsteins,Marlin Crawler Nilights LEDs fog & flood Yakima roof racks. 31'"BFG K02's
    So am I to believe a deck plate is better than a K&N op-en air flow????
  11. Apr 25, 2013 at 9:04 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    After owning my Tacoma now for 2 years, coming from a 2005 Subaru WRX STi, this is what I have learned.
    1.) The Tacoma is a 3,500 lb. underpowered truck. However, the power band is right around 4,800 RPMs, which is perfect for what this truck was designed for which is low-to-mid range power and torque for climbing, towing, pulling, and off road conditions.
    2.) That being said, this truck will never be fast, and it will never get amazing gas mileage.
    3.) You can spend $1,000 on "performance" mods, and you'll still be disappointed so just enjoy the truck for what it is. A solid, bullet-proof, reliable truck that is well respected for its history. The sooner you realize everything I mentioned above, the happier you'll be with the truck.
  12. Apr 25, 2013 at 5:05 PM
    blknblubkrdude
    blknblubkrdude Well-Known Member
    Gillette, WY
    96 Taco. 4X4, 5MT, 2.7
    Oil field truck with 250k miles...original powertain. Wheelers 881's/5-pack, Energy bushings throughout.
    No mod you are going to do to the 2.4 is going to "Wow" you.
    Before you waste a nickel on a "performance" mod, consider a new vehicle, or an engine swap (think LSX)
  13. Apr 25, 2013 at 5:11 PM
    Silver4cab02
    Silver4cab02 Member
    AEM Brute Force cold air induction
    Lower ratio differentials
