Simple Scangauge II Mounting Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Detective_Dan, Jan 19, 2011.
  1. Jan 22, 2011 at 4:29 AM
    #41
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    Epoxy :D
  2. Jan 22, 2011 at 1:05 PM
    #42
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    FTW!!
  3. Jan 30, 2011 at 5:30 PM
    #43
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I liked your idea. So, I went to the dollar store, got the tape measures.
    I noticed that there are screws holding the clips to the tape measure and I wanted to see if there was room inside the scangauge to screw the clips on.
    There is. There is about 1/2 inch of open space inside the scangauge. The circuit board is near the front panel where the screen and buttons are. The back 1/2 of the case is just to add depth for the black connector plug in the center.
    I just drilled 2 1/8" holes and screwed those screws in.
  4. Jan 30, 2011 at 5:35 PM
    #44
    Detective_Dan
    Colorado Springs
    do whatever works. nice job
  5. Jan 30, 2011 at 5:41 PM
    #45
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :bowdown: great idea!!!!!. Thanks guys. Right now mine is sitting on the steering column because I didn't want to spend the $$ on the blendmount.
  6. Jan 30, 2011 at 7:45 PM
    #46
    Detective_Dan
    Colorado Springs
    my thoughts exactly! thats y i started brainstorming lol
  7. Jan 31, 2011 at 12:28 AM
    #47
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    YEP I screwed it as well. Only I used a single screw so it swivels...LOL
    I did the mod and mounted it upper left of cab using a single clip I used a small metal screw and screwed the clip to the Scangage. I found a clip on a belt spring loaded key ring and unscrewed it and found the screw was the perfect size to do the job with a single clip.
    I took four screws out of the Scangauge and removed the back cover. Found plenty of clearance to drill a pilot hole next to the jack and screw the clip on with the small metal screw. The gauge looks flush mounted to the headliner on he upper left corner of the windshield. Can't see the clip.
    Removed the A pillar and ran the end to the connector..PROFIT!!
    tried tape and did not like the white. Black tape didn't hold so what the hell I put a screw in the Scangauge and for safety put some double sided tape over the inside where it sticks out plenty far from any circuitry,
    Lovin the Scanguage data. Buying an extra data cable to check the wife's RAV if it should throw a code.
  8. Jan 31, 2011 at 12:32 AM
    #48
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Not bad! good thinking! :thumbsup:
  9. Jan 31, 2011 at 7:47 PM
    #49
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    about taking out the a-pillar: I remember on my hyundai, taking out plastic trims was the same as scrapping them as they would often break a bracket when taken off. Is there any precautions to take for removing the a-pillar in a tacoma?
  10. Jan 31, 2011 at 8:54 PM
    #50
    Detective_Dan
    Colorado Springs
    just be gentle with it and you will be fine
  11. Jan 31, 2011 at 9:41 PM
    #51
    Kingfrog
    If I can do it anyone can...just pop out the caps unscrew the two bolts holding the "oh shit" handle and it practically falls out.
  12. Feb 1, 2011 at 5:07 PM
    #52
    jgang
    jgang Well-Known Member
    Nice! That's friggin great!
  13. Feb 1, 2011 at 6:53 PM
    #53
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    Anyone done this mod with the Scangauge II? Is it that the SG II is too tall to fit between the headliner and the mirror?
  14. Feb 1, 2011 at 8:28 PM
    #54
    Kingfrog
    I think you should reconsider putting it in the upper left of the windshield. Running the cable down the A pillar is easy and it fits fine there. I have my hardwired GPS to the left of the mirror. The Scanguage II works well on the left upper corner.
  15. Feb 1, 2011 at 8:31 PM
    #55
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    This would have been great if I still had mine. Got rid of it because I couldn't decide on a good mounting location and this one seems like it would have been great. :thumbsup:
  16. Feb 23, 2011 at 3:52 PM
    #56
    ImpulseRed008
    Susan
    SC
    This is the one I was thinking of earlier...
  17. Feb 23, 2011 at 3:54 PM
    #57
    Detective_Dan
    Colorado Springs
    lol ya i quoted you in the thread for free shit with this link
  18. Feb 23, 2011 at 4:04 PM
    #58
    ImpulseRed008
    Susan
    SC
    I saw that :D thanks
  19. Feb 23, 2011 at 4:05 PM
    #59
    Kingfrog
    No..My GPS is much larger and overlaps the mirror a bit
  20. Feb 23, 2011 at 5:37 PM
    #60
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    You mean, like this?
    I should'vedusted though .. lol. I don't know about moving it up there. It makes looking at it almost like I'm taking my eyes off the road.
