Simple UCA debate
Discussion in 'Suspension' started by Chukwithak, Nov 24, 2022.
Which?
  1. Icon billet with Delta Joint - $925
    6 vote(s)
    16.2%
  2. SPC - $700
    31 vote(s)
    83.8%
  1. Nov 24, 2022 at 12:42 PM
    Chukwithak
    Chukwithak [OP] Well-Known Member
    Charlie
    Eldorado Hills, CA
    ‘21 Cement DC TRD OR 4x4
    Leitner ACS, iKamper BDV, Switch Pro, Decked
    Which for my daily driver I will crawl in 6-12 times a year.
    Icon Billets with Delta Joint for $925
    or
    SPC for $700
    Poll is above!
  2. Nov 24, 2022 at 1:35 PM
    Chukwithak
    Charlie
    Eldorado Hills, CA
    I’m not seeing them for a “little” more. Lol
  3. Nov 24, 2022 at 1:39 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    I've heard great things about SPC's as long as you aren't constantly beating on your truck off road. In your situation SPC's would be great.
  4. Nov 24, 2022 at 1:41 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    If your fine with doing a cab mount chop and losing lots of clearance go with the icons. They are solid and last a long time. If you want better tire clearance and tuneability for offroading go with SPC but you expect to replace the ball joints every 10-20k miles.
    AccuTune Offroad likes this.
  5. Nov 24, 2022 at 1:59 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Get the billet Camburgs
    Worth it!
    You get to tell people they are K-IN-E-TI-K
  6. Nov 24, 2022 at 2:21 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Icons might need the heim rod ends replaced every 20k miles depending on climate. Might last a bit longer in Cali.
    The ball joint boots on my SPC UCAs like to develop small cracks. Replaced the boots last year ($30-40) and the new boots are leaking grease again.
  7. Nov 24, 2022 at 9:03 PM
    HIallday
    HIallday Well-Known Member
    Hilo
    2019 TRD OR
    You could get the mevotech ones from rock auto. It is spc in a mevotech box for a lot cheaper.
    3JOH22A likes this.
  8. Nov 24, 2022 at 9:21 PM
    MGMDesertTaco
  9. Nov 25, 2022 at 9:33 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  10. Nov 25, 2022 at 11:35 AM
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    Why not jbas?
  11. Nov 26, 2022 at 2:18 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    JBAs. Currently have 80k on my current set, zero ball joint play, zero bushing play, granted it’s just my daily street and roads to my hiking spots. But zero issues.
  12. Nov 26, 2022 at 3:01 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Non. Jd fabrication ucas is my vote
    Bcjammerx and 01 dhrracer like this.
  13. Nov 26, 2022 at 3:10 PM
    Bkicks333
    Bkicks333 Well-Known Member
    James
    Trd offroad 4x4
    Dirt king boxed heim joint
    MulletTaco likes this.
  14. Nov 26, 2022 at 3:19 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
  15. Nov 29, 2022 at 7:46 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
  16. Nov 29, 2022 at 7:52 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Why you sleeping on JBA?
    You don't need the billet's but I can't recommend SPC to anyone when there are so many better options.
  17. Nov 29, 2022 at 8:04 AM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    I looked at the jba. You can only adjust caster with those. If you locked the camber bolts into place like with taco tabs, you can’t adjust camber. Spc allows for camber to be adjusted on top.
  18. Nov 29, 2022 at 8:47 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    You might want to do some more research on how the alignment works on these trucks, and how the SPC's work. You can adjust caster on the top of the SPC's, not camber. Any camber +/- is a result of the caster change. A shop that knows what they're doing can adjust camber and caster from the eccentrics on the LCA's on these easily. The JBA's just lay the spindle back to add 3 degrees pf caster over stock in a fixed position and without an additional unnecessary adjustment on the upper ball joint that can fail, and with a much higher quality ball joint. If you made a big enough change to the truck where you need to adjust the camber or caster after locking down the eccentrics with the taco tabs you could easily change out their inserts for a different setting. And with how sensitive these trucks are, if you made a change to the bj orientation on the SPC you'd likely need to adjust the eccentrics anyway. The SPC's have crap non-greaseable bushings and bj's that seem to fail left and right. Sure you can make unnecessary adjustments on the top but it's such a PITA to do and just more stuff to fail, hard pass from me.
    EDIT: I learned they are actually camber adjustable, but this still doesn't seem like a reason to buy them over other options IMO.
  19. Nov 29, 2022 at 9:16 AM
    AccuTune Offroad
    El Cajon, CA
  20. Nov 29, 2022 at 10:28 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    SPCs (at least mine) have both a caster adjustment and a camber adjustment.
