Simple UCA debate
Discussion in 'Suspension' started by Chukwithak, Nov 24, 2022.
Which?
  1. Icon billet with Delta Joint - $925
    6 vote(s)
    16.2%
  2. SPC - $700
    31 vote(s)
    83.8%
  1. Nov 30, 2022 at 12:30 PM
    #61
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’ve a number of posts on here explaining that the bushings and ball joint have some play in them by design. How did you inspect them? Did you inspect them when new?
  2. Nov 30, 2022 at 12:38 PM
    #62
    saint277
    saint277 Vigilo Confido
    Believe this is what you are talking about(page 6). The joint is under spring force that can be overcome with high force, not really "play".
    https://www.spcalignment.com/partFAQ/25470_FAQ.pdf
    gudujarlson[QUOTED] likes this.
  3. Nov 30, 2022 at 12:41 PM
    #63
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Spc’s have been trash recently. They have had a huge amount of inner x-axis bushings fail and ball joint failures.
    Dalegribble02 and Darkice like this.
  4. Nov 30, 2022 at 12:42 PM
    #64
    Darkice
    Darkice Well-Known Member
    I didn't mess with them when new but after a few thousand miles I started to notice a slight clunking when going over small bumps when turning. It got worse after a while so that's when I started looking into it.
    I jacked up the truck and noticed quite a bit of play from the ball joints when I pushed on the tire. The shop swapped the ball joints under warranty and said they were definitely loose. After the warranty install I still had the loose knocking noise. I found that I could recreate the noise by grabbing the uac and shaking it. I can also feel that it's loose when I do this.
  5. Nov 30, 2022 at 12:44 PM
    #65
    gudujarlson
    Minnesota
    TVH475 likes this.
  6. Nov 30, 2022 at 1:38 PM
    #66
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    wi_taco and Darkice like this.
  7. Nov 30, 2022 at 1:42 PM
    #67
    gudujarlson
    Minnesota
    That video does not make it clear that you are following the inspection procedure
    It might just be an aspect of the video, but it looks like you have play in your wheel bearing. I see the top of the tire moving in and out. It’s really hard to tell though.
    Brian422 likes this.
  8. Nov 30, 2022 at 1:59 PM
    #68
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    The up and down movement in BJ is probably wear spring, my money is it was fully drooped out as well when tested.
  9. Nov 30, 2022 at 2:07 PM
    #69
    gudujarlson
    Minnesota
    One key thing everyone should understand about UCAs is that they are not load bearing. The LCA is what supports the weight of the truck. The UCA simply keeps the spindle in the correct orientation.
    Everyone should also understand that a balljoint is like a door hinge. It’s supposed to have “play” (in the designed degrees of freedom) to allow the suspension to cycle.
    One last note… bushings are designed to be squishy in order to soak up vibration. If you want a race truck like suspension with little or no play, you should look at racing UCAs with heim joints and uniballs or some thing similar.
  10. Nov 30, 2022 at 2:12 PM
    #70
    MGMDesertTaco
    It seems like a uniball uca would be better suited for 2.5 applications than ball joint uca if you're really giving the truck a work out. :notsure:
  11. Nov 30, 2022 at 2:19 PM
    #71
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
  12. Nov 30, 2022 at 2:30 PM
    #72
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    the inner bushings are what Spc calls X-axis bushings. However they are sealed heims which should have no play. While it looks like the wheel bearing has play it’s all movement in the uca. Between the inner X-axis joints and the ball joints all 3 had movement. There was 1 inner bushings that had no play when I put a dial indicator on it. These were the remaining videos I had on my phone from when I warrantied mine out. In this video the lower arms were not supported but even when they were the upper ball joints had lateral play in them not just vertical play.
    If you look at the cutaway of spc’s X-axis it’s just a type of sealed heim. The shop i used to work at had the correct replacement X-axis on hand but I decided to warranty the entire arms out and replace them with something else.
    https://www.spcalignment.com/component/content/article?id=291#SealedFlexJoints
  13. Nov 30, 2022 at 2:55 PM
    #73
    gudujarlson
    Minnesota
    Maybe we are taking about different products. I believe my SPC UCAs have SpecRide bushings with an option to upgrade to xAxis bushings. The SpecRide are normal polymer bushings I think.
    https://www.spcalignment.com/component/spc/?task=part_description&pid=25470
  14. Nov 30, 2022 at 3:54 PM
    #74
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    The spec ride bushings are for the older tubular arms and the newer cast arms were originally available with either a rubber bushing or x-axis but Spc discontinued the rubber bushings. The x-axis bushings on our trucks are suspended in a very thin layer or rubber. When they fail they make quite a loud clunk. If you watch the video you will see movement at the rear bushing where the control arm is moving in and out. It was difficult to capture on video.
  15. Nov 30, 2022 at 7:26 PM
    #75
    gudujarlson
    Minnesota
    I could easily be wrong.
  16. Nov 30, 2022 at 8:31 PM
    #76
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    why do you think you need aftermarket ball joints? are you SURE you need aftermarket adjustable ones? If you really are, then prepare to spend much more than $500...you only get what you pay for, you get cheap parts you won't like it in the long run and you're going to do much more harm than good. you gotta pay to play, there is NO getting around that
  17. Dec 4, 2022 at 7:16 PM
    #77
    MGMDesertTaco
    Not sure, but I'm going to guess and say no. There appears to be a lot of play and slop in those. I'm definitely not going with SPC after reading all the recent reviews about them.
