Simple, yet effective ABS cut
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spoonman, Mar 17, 2012.
  1. Mar 17, 2012 at 4:38 PM
    Spoonman
    Spoonman [OP] Granite Guru
    Jamie
    Alberta
    Ive just been taking out ABS fuse #2 to disable my ABS. It gets a little annoying taking out the fuse. I didn't really want to cut into any wires either. Decided to put in a little switch to make things easier and quicker. This is how I did it.
    Here's what you need
    (and a little bit of wire)
    Took out the fuse I wanted to put a switch to. I put a small wire from the fuse box, to one of the terminals of the fuse. Then from the other terminal on the fuse, to a switch, and back to the fuse box.
    Like this..
    Basically, plug the female connectors into the terminals where the fuse would go. Then flip the switch on or off, ABS on or off. I did a short version, to keep it simple and have the switch in the fuse box.
    I will extend the side with the switch to the can, with a factory switch.
    My truck doesn't have VSC or ATRAC. So I don't have to worry about those. This is a pretty simple way to cut your ABS and not have to worry about splicing into wires in your engine bay.
  2. Mar 17, 2012 at 4:43 PM
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    Pardon my ignorance, but why would you want to disable the ABS?
    Ray
  3. Mar 17, 2012 at 4:45 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Sucks in snow and loose material offroad
    Looks good OP
  4. Mar 17, 2012 at 6:32 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Is that 12ga wire and is the switch rated for 30A minimum? If not, you'd be better off reinstalling the fuse and installing a switch inline with pin 4 of the 1B1 connector. See the ABS w/out locker thread for more info. Best of all, all wiring mods stay inside the cab, and it can be switched on the fly, with no need to cycle the key off to reset.:cool:
  5. Mar 17, 2012 at 6:33 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    For offroad use.
  6. Nov 19, 2012 at 4:58 PM
    goualon69
    goualon69 Well-Known Member
    Mathieu
    Québec, Canada
    2011 sr5 tacoma
    I am planning do do your mod! How do you end up? do you run a 12g wire in the cabin?
  7. Nov 19, 2012 at 5:02 PM
    Spoonman
    Jamie
    Alberta
    I still have it like this lol. I'm thinking of putting a real matching switch inside the cab still. But it has been workin perfect so far.
  8. Dec 16, 2012 at 3:58 PM
    Backinblack03
    Backinblack03 Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS sucks.
    Put a 30A relay under the hood. Put the switch in the cab.
  9. Mar 25, 2013 at 8:40 AM
    Jaws9760
    Jaws9760 Active Member
    Northern Idaho
    2013 V6 4x4 DCLB TRD Sport MagGrey
    Bed liner shovel mount, head rest vertical rifle mount, console .380 holster. Tailgate hose clamps & washers. Green LED dome light, Disabled seat belt chime.
    Hey Spoonman, that's a snazzy idea. I'm just looking into disabling ABS and all the wiring mods are scaring me off. I don't care about a switch, I'd just like to pull a fuse.
    Just to clarify, pulling ABS No2, the smaller amp fuse in the engine fuse box worked for you? Did it disable anything else? Did you get a persistent dash light? Thank you.
  10. Mar 25, 2013 at 9:00 AM
    LTCal
    LTCal Member
    Cal
    La Grande, OR
    2013 Tacoma TRD Offroad
    Okay i need a better explanation besides "Its better for offroading" what disadvantages does having your ABS system put you when driving? What are you gaining by disabling it?
  11. Mar 25, 2013 at 9:02 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Same here, I'd like to do it to mine and have it off permanently, anyone who is a good driver should be much better off without it. I personally think the ABS in these trucks is more of a hazard than a convenience on snow and ice.
  12. Mar 25, 2013 at 9:06 AM
    Jaws9760
    Northern Idaho
    There's a lot of discussion on TW about ABS and why a lot of folks don't like. Certainly more learned and mechanically inclined people than I have tackled the question. I can only speak from my experience.
    ABS systems can be scary in the snow. If you grow up driving in the ice and snow then you know to stay calm, pump the brakes, turn into the skid...you get the idea. ABS kicks in and basically pumps the brakes for you and it's supposed to preserve steering control, it's for people who freak out and just mash the brake. I've never liked ABS myself and after reading how touchy it is in the Tacoma, I want it turned off.
    Dunno man, definitely a personal preference thing.
  13. Mar 25, 2013 at 9:14 AM
    OZ-T
    Peter North
    British Columbia
    ABS INCREASES stopping distances , particularily on snow , this is why I hate it , and it is definitely sensitive on these trucks for some reason
  14. Mar 25, 2013 at 9:18 AM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    I was under the impression that it is shut off in 4wd, at least it is in 4lo, are you talking about just 4hi?
