Simpler solution for disabling the DCM telematics - Silencing Antennas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by altitude-nerd, Jan 7, 2024.
  1. Feb 1, 2024 at 4:00 PM
    #81
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Oh, I will, but this is not on my immediate agenda.
    koditten[QUOTED] likes this.
  2. Feb 1, 2024 at 4:08 PM
    #82
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    2017 owner's say... Whatchu Talking about?
  3. Feb 1, 2024 at 4:37 PM
    #83
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    2012 owners: *laughs in analog*
    Now that I see the title, I recall reading the first page or two of that thread linked just above. Totally forgot they mentioned the antena might actually be inside the module
    koditten likes this.
  4. Feb 1, 2024 at 5:34 PM
    #84
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    "Laughs in analog". Hilarious!
    :rofl::rofl:
    SR-71A likes this.
  5. Feb 1, 2024 at 5:48 PM
    #85
    Disgruntled Scientist
    Disgruntled Scientist Active Member
    '22 4x4 V6 DCSB TSS Barcelona Red
    6112/5160, 3L AAL, 4.88 F&B E-Lockers, OTT
    Way ahead of you.
    I was only half joking about wrapping the DCM module in foil. Get your tinfoil hats ready boys. I pulled out the DCM module, wrapped it in aluminum foil with the internal battery still installed, cut holes for the electrical connections with a razorblade, and reinstalled the DCM module with the short ungrounded adapters and termination resistors. Then I drove the truck around and made sure to drive right by two different cell phone towers. Parked the truck and so far no updates on the Toyota website for 2 hours. Previously the website updated somewhere between instantly and 30 minutes. I will continue to check the Toyota website over the next few days but this is good so far.
    Removing and reinstalling the module wasn't difficult. Two bolts hold the DCM module to the module next to it. I would recommend loosening the bolts attaching the adjacent module to the truck so that you can shift it out of the way slightly to reinstall the DCM module without tearing your new faraday cage. I was able to do everything in a little over an hour but I have also gotten very good at removing the glovebox troubleshooting this mod.
    You can stop procrastinating now.
    DCM/Telematics Module
    Internal battery of DCM module
    Wrapped in foil
    Electrical connection cutouts
    DCM module reinstalled
  6. Feb 1, 2024 at 6:16 PM
    #86
    Toycoma2021
    You have been persistent.
    Edit: Next try putting back the three antenna leads and see what happens.
  7. Feb 1, 2024 at 6:45 PM
    #87
    I ordered some "EMP tape" (https://www.amazon.com/dp/B097HC9HR7?smid=A3E3M0W7EF6TKV&th=1) to replace the aluminum foil and make it a bit cleaner. If all goes well I will try reconnecting the antenna leads when I have everything taken apart.
    DrRansom, MattiasdelTaco and koditten like this.
  8. Feb 1, 2024 at 7:06 PM
    #88
    Toycoma2021
    I wonder how the adhesive affects the continuity from one layer of the tape to the next?
    Go ahead and open the DCM. Give us a peak. Usually just some plastic clips on the box separating the halfs; or at least it was on my BCM ECM.
  9. Feb 1, 2024 at 7:57 PM
    #89
    immortalize
    immortalize Member
    Oregon
    22 DCLB TRD OR Lunar Rock
  10. Feb 2, 2024 at 5:31 AM
    #90
    SR-71A
    Zack
    Southern Maine
    Well there ya go. Folks must have missed that before. Id say that in conjunction with your tinfoil test prove it
  11. Feb 2, 2024 at 5:20 PM
    #91
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    And it hasn't gone completely off the rails either! 10/10, will read again.
  12. Feb 3, 2024 at 5:38 PM
    #92
    Toycoma2021
    Well curiosity got the better of me and I got into the Module. Could find no obvious antenna on the PCB or case. If others wish to investigate opening the module was simple simple. Remove the metal shield from one side and pry off the ends where the connectors are and slide the card out the connector end - no need to remove the bracket, or the module from the bracket.
    Edit: Also open battery compartment and remove battery first before removing the metal plate and plastic around the connectors.
  13. Feb 3, 2024 at 7:46 PM
    #93
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Maybe under that Kyocera tagged shield with the IMEI number? Kind of looks like a laptop wifi module.
    Canadian Caber likes this.
  14. Feb 3, 2024 at 7:48 PM
    #94
    immortalize
    immortalize Member
    Oregon
    I had the same thought.
  15. Feb 3, 2024 at 8:01 PM
    #95
    Toycoma2021
    An antenna under a metal shield I believe would shield the signal from getting out, just like the aluminum foil used above. Laptops have cabled antennas away from the electronics, at least the ones I have had the misfortune of opening up. I am thinking it may be more like the iPhone that has the antenna embedded in the case (those lines a few MM wide) with just some little traces on the PCB that are the antenna. I did notice some strange traces I could not make sense of, but this is a multilayer board and the antenna could be in any layer.
    Toy_Runner likes this.
  16. Feb 3, 2024 at 8:09 PM
    #96
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    The fact it’s sandwiched in between two metal plates didn’t escape me but having the antenna inside the pcb I didn’t think of.
    There are those 5 solder points on the back side that caught my eye. Maybe a little desoldering action would neutralize it. I can’t imagine these are in demand enough on the 2nd hand market to cost an arm and a leg to get a unit to mess around with?
  17. Feb 3, 2024 at 8:27 PM
    #97
    Toycoma2021
    Those 5 solder points also caught my eye so I looked at the traces a bit and I think that is for an onboard soldered battery. I'm sure you could pick one up at a dismantler.
    Edit: Hold on what five solder points on the back side? I was thinking the six on the component side of the board when I mentioned the battery.
  18. Feb 3, 2024 at 8:34 PM
    #98
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    That’s starting to get pretty far beyond my comfort zone. But, I would be all for pooling some resources to get something in the hands of someone competent to experiment with.
  19. Feb 3, 2024 at 8:38 PM
    #99
    Toycoma2021
    A search of the Model: "AL-T52V1" brought up a lot of information. Some you have to pay for.
    Beyond my capacity at this point too.
    immortalize likes this.
  20. Feb 3, 2024 at 9:08 PM
    #100
    immortalize
    immortalize Member
    Oregon
