Simplified question on BS. Can't find answer
Discussion in 'Wheels & Tires' started by 1GR, Mar 12, 2012.
  1. Mar 12, 2012 at 5:31 PM
    1GR
    1GR [OP] Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Now I know 265/75R16* with a 4.5 bs will not rub. Even with an aggressive tire. Now how about the same tire, with 4" bs? Just want that little extra for the aggressive look/stance. Anyone done this, and did you have any rubbing issues?
  2. Mar 12, 2012 at 5:36 PM
    Large
    Large Red
    265/75/18 is an awkward size, do you mean 265/75/16?
  3. Mar 12, 2012 at 5:37 PM
    1GR
    Scott
    BC, Canada
    Yes. Typo. I'll edit.
  4. Mar 12, 2012 at 5:54 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    the less backspace the further out the tire will stick. Backspacing is the linear distance from the rear of the hub to the rear lip of the rim. In essence it will stick out another .5 inches. I doubt that will be a problem.
  5. Mar 12, 2012 at 6:17 PM
    1GR
    Scott
    BC, Canada
    I am aware of what bs is and how it affects stance, spacing, etc. Just wondering if anyone has done the 4" bs, and if it rubbed on the outer rear corner of the fender/mudflap?
    Fact: 16x8 with 265/75R16 4.5" bs will fit no trimming, no rubbing, with mud flaps
    Question: 16x8 with 265/75R16 4" bs... Trimming/mudflap removal required?
  6. Mar 12, 2012 at 9:43 PM
    JC47
    JC47 Well-Known Member
    British Columbia
    08 TRD Sport DCLB 4X4
    OME 885, 5100's, 1.5 AAL, DC2's, 265/75/16 Duratracs. Leer Cap, Debadged.
    I can't answer for sure, but I think they might rub if you don't have a lift on your truck. I have 265/75/16's mounted on wheels with 4" backspacing sitting in my garage right now which I will be putting on in a couple of weeks, but I'm also lifted 2.5". I know there is someone on here that had rubbing issues with that size tire and 4" bs with no lift.
  7. Mar 12, 2012 at 9:44 PM
    1GR
    Scott
    BC, Canada
    Will have 3" front, 1-2" rear.
  8. Mar 12, 2012 at 9:45 PM
    1GR
    Scott
    BC, Canada
    Let me know if you have issues. Is the tire fairly aggressive you're putting on?
  9. Mar 12, 2012 at 9:50 PM
    JC47
    British Columbia
    They are goodyear duratracs, so fairly aggressive.
