Single AAL vs. 3 Leaf AAL
Discussion in 'Suspension' started by RRR13, Apr 25, 2017.
  1. Mar 15, 2019 at 11:29 AM
    #81
    Gary86
    Gary86 IG: 2a_Aviator
    Gary
    Corpus Christi, TX
    2018 DCSB Cement TRD 4X4
    Same. Between wheelers and headstrong. Was looking at Toytec but they are more expensive than Icon.
  2. Mar 15, 2019 at 2:58 PM
    #82
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    I'm going with Wheeler's because they show 1.5 inches of lift, which is exactly what I want. Leaning towards the single AAL instead of progressive.
  3. Mar 15, 2019 at 3:28 PM
    #83
    Gary86
    Gary
    Corpus Christi, TX
    So was I but everyone was saying the single AAL make the ride rougher due to 1 leaf creating the lift vice 3 ¯\_(ツ)_/¯
  4. Mar 15, 2019 at 3:38 PM
    #84
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I was told that the single ride is slightly rougher, but holds load better (which was the main point for me) and likely won't start to sag.
    Progressive is nicer ride but may start to sag over time, and doesn't help with load carrying as much.
    Jukeboxx13 likes this.
  5. Mar 15, 2019 at 4:20 PM
    #85
    Gary86
    Gary
    Corpus Christi, TX
    hmmm, interesting. Thanks. I actually thought about a block bc I want a level stance and I know a block won't sag but ride will suffer.
  6. Mar 15, 2019 at 6:00 PM
    #86
    Philsummers21
    Philsummers21 Well-Known Member
    Phil
    20 OR LB
    Icon stage 4, 285/75-17 KO2, 5.29 gears
    So what about a progressive with the overload vs a single AAL for more load capacity
  7. Mar 16, 2019 at 4:31 AM
    #87
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I'm just going to try the single AAL and see what happens. Costs less than $100, so if I don't like it I'll just try something else.
  8. Mar 16, 2019 at 4:17 PM
    #88
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    I just put the Icon 3-leaf on a set of 3+OL stock (TSB update) packs. I wanted to leave the overload in, and after putting one together, had the idea to pull the shortest one back out, for a little less lift and hopefully to make the overload work more properly. With that tiny one in there, it looked like it'd squat a ton before the overload hit the 2nd leaf.
    It sits a hair above level with 5100/885s (also new) and rides just a little rougher than I think it should feel stock. With stock springs @ 130k (looks like my stock leaves had been replaced in the recall, but were only 2+OL) I thought it was way too squishy. For reference, I think they ride better now than my Wheeler's leaf pack in my 1st gen, even though it weighed close to 4500lb.
  9. Mar 19, 2019 at 6:12 PM
    #89
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Are you all pulling the leaf springs off the truck to install the 3 leaf AAL or leaving them on the truck?
  10. Mar 19, 2019 at 6:16 PM
    #90
    RocRan26
    RocRan26 Well-Known Member
    Randy
    Rochester NY
    2017 Black Tacoma Limited DCSB AT
    The only thing I pulled off was the overload. Everything else stayed clamped and in place.
    308savage likes this.
  11. Mar 19, 2019 at 6:28 PM
    #91
    RocRan26
    Randy
    Rochester NY
    To be clear I did reinstall the overload with the new 3 leaf aal. Just try to drop the axle as much as possible to make room to slide everything back in.
  12. Mar 19, 2019 at 6:35 PM
    #92
    Gary86
    Gary
    Corpus Christi, TX
    how's the ride w/ 3 AAL and OL?
  13. Mar 19, 2019 at 6:43 PM
    #93
    RocRan26
    Randy
    Rochester NY
    Did that along with Bilstein 5160s. It’s only been 2 days but I would say definitely better than the stock leaf pack and Hitachis.
  14. Mar 19, 2019 at 6:46 PM
    #94
    fb40dash5
    11 V6 AC 4x4
    Mine rides great, IMO anyway. I'm used to a little firmer ride though, I had a Wheeler's pack on my 1st gen, and I thought the stock 2nd gen springs rode like a Caddy. The overload shouldn't even matter until you go past flat, other than adding their thickness in lift.
    I did pull the shortest of the AAL. I figured I'd rather have an overload leaf than not, and I thought I'd rather have it a little soft than too firm, plus with the full AAL pack + the overload thickness it might end up higher than I wanted.
    I don't know that it would've been too firm or too high with all 3 extra leaves, but I do know I'm happy with both the way I did it. Plus the last leaf is way short for the overload to hit it, so it'd have to sink that much more to flex past that one and hit the next leaf.
  15. Apr 11, 2019 at 4:19 AM
    #95
    Leathermatt
    Leathermatt Well-Known Member
    Boston, MA
    2016 SR MGM ACLB 4x4
    255/85/16 Cooper ST Maxx 33s Midland CB Radio w/ A-Pillar Mount KB Voodoo Mid-Rise Bed Rack Bedrail-Mounted Headache Backrack OEMassive LED Sequential Headlights Tail Light Guards w/ VHT Niteshades Tint 50" Curved LED Cree Lightbar w/ MCM Fab Brackets 3" LED Front/Rear Lower Cube Lights (OZ Pods) 2" LED Fog Light pods (OZ Pods) MBRP Ditch Light Brackets w/ 2" OZ Pods Bushwhacker Bolt-On Style Fender Flares Rear EVO3 Bumper Guard Plasti-Color Flushmount Mudflaps Rear Cabin mounted Survival Bag/ Medical Kit Black 3" Access Cab Nerf Rails Black Powdercoat Fine Mesh Grill (Customgrills.com) Black Metal Grenade Grill Emblem Insert 2" Black Receiver Hitch w/ Pintle Hitch or D- Shackle Black Aluminum 21" Toolbox Interior Black Leather Seat Covers Weathertech Window Visors Weathertech Hood Bug Deflector
    Will I need extended break lines for either of these options on my 3rd gen? Probably about 100 lbs in the bed, thinking about the HS 3 leaf. Thanks!
  16. Aug 10, 2019 at 6:14 PM
    #96
    MNlaw
    MNlaw @Overland_Minnesota
    2019 Quicksand TRD Off-road DCSB
    Been looking at this kit too and wondering which AAL option to go with. Seems like the single holds weight better but rides stiffer; whereas, the 3 leafs rides smoother. Am I understanding that right?
    Also, lots of people said they would post up pictures or updates on their rides. Any update by you guys? And how much lift does the 3 pack provide-I’m leaning that way
  17. Aug 11, 2019 at 4:14 AM
    #97
    Jblud1986
    Jblud1986 Well-Known Member
    Middleburg, FL
    TRD Off-Road 4x4
    Bilstein 6110 650# coils 3 leaf add-a-leaf in rear SCS Ray 10s -38 with bronze finish 35/12.5 MT Baja Boss ATs JBA Off road UCA's Diode dynamics lights Relentless Fab hybrid bumper CBI sliders
    3 leaf aal 1.5"
  18. Aug 11, 2019 at 5:41 AM
    #98
    RocRan26
    Randy
    Rochester NY
    I got exactly 2” lift with the overload left in.
  19. Aug 13, 2019 at 7:00 AM
    #99
    Titus139
    Titus139 Well-Known Member
    Tim
    NorCal
    2011 Tacoma DCLB
    Great info. I’m on the fence on this exact same set up. Looking at the H.S. Bilstein 2” coils up front and 3 leaf for the back of my 2011 DCLB. Looking at wanting 2” with a slight rake on the back. Anyone have this setup they can comment on? Thanks in advance.
  20. Mar 5, 2021 at 10:44 AM
    #100
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    Just installed Deaver single, kept overload and can say:
    1. Easy install.
    2. Exactly 1 5/8” lift.
    3. Rides the same as stock.
