Single (and Two) Piece Driveshaft = Vibes....BE GONE!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Feb 16, 2017.
  1. Mar 29, 2017 at 4:07 AM
    #181
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    Former owner of a 12 TRD Sport AC 4x4
    I'd say it's due to the longer driveshaft on non 4x4s. Longer = lower critical speed and they don't want to mess with it.
    01 Runner[QUOTED] likes this.
  2. Mar 29, 2017 at 5:52 AM
    #182
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Yes, without the 4x4 transfer case the shaft required is an extra foot or more longer which is why they don't do it. Think about it, you'll be bolting it directly to the transmission output instead of having the transfer case in the way. :)
  3. Mar 29, 2017 at 8:46 AM
    #183
    im4u2nvss
    im4u2nvss Well-Known Member
    Jesse
    2012 DC
    Did this start as a first gen tacoma driveshaft?
  4. Mar 29, 2017 at 8:47 AM
    #184
    1MK
    1MK Desert Explorer
    Southern California
    No, it's 100% custom built.
  5. Mar 29, 2017 at 8:49 AM
    #185
    im4u2nvss
    Jesse
    2012 DC
    Was there an option to go with a larger splined section where this failed? Also, how much $?
  6. Mar 29, 2017 at 9:00 AM
    #186
    1MK
    1MK Desert Explorer
    Southern California
    No, not according to the numerous driveline shops I talked with. The problem is trying to retain the Toyota carrier bearing and flanges. You can go full custom with a different carrier bearing but it will require crossmember modifications for mounting and it'll be a mixed bag of components to make it work, and also much, much, much more expensive.
    That being said, it will be what I do next if this one piece has another issue.
  7. Mar 29, 2017 at 11:01 AM
    #187
    01 Runner
    01 Runner Well-Known Member
    San Marcos,Texas
    (Old Man Tan) 2001 Pre-Runner
    2001 Tacoma Build (Started 03/17) Mods done- Wheels- -method nv's 16x8 4.5bs 0 o/s -Bfg a/t 285/75r16 Suspension- -king coilovers 2.5 (non resi) -total chaos uca -bilstein 5100 rear shocks -ome dakkar leaf springs Tech/Lights/Cool Mods- -HELLA lights mounted on bumper -Righid D2s mounted inside bumper -CB radio with rear tailgate mount -deck plate mod (actually worth it) Armor- -Relentless Fab “Predator” bumper Winch- WARN m8000 (steel cable) ————————————————————————— Mods to come- -rear bumper (relentless fab) -arb air rear locker -4x4 conversion (way down the road) -new exterior window trim -fender flare delete & 35’s -new tint -new headlights -full size spare tire -tire carrier/hi-lift/jerry-can mount
    Damn, that makes sense. I would happily pay $500 to fix this problem
  8. Mar 29, 2017 at 11:06 AM
    #188
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    Question for the people that are using the 1 piece shaft. Are you using shims in the rear too? And if so what degree?
    I used a TW driveshaft on my lifted Cherokee, it was the cats ass.
  9. Mar 29, 2017 at 11:32 AM
    #189
    UfoPaycheck
    UfoPaycheck Member
    I'm using 2.5 degree shims with mine. I've heard it's one degree for every inch of lift.
  10. Mar 29, 2017 at 11:35 AM
    #190
    TacoRob08
    Rob
    17 Sport DCLB
    OK, good to know.
  11. Mar 29, 2017 at 12:20 PM
    #191
    evskie53
    evskie53 The Problem Child
    Denver
    2011 DCSB Sport
    PTM, do your vibes go away in 4 wheel drive? If so, you might want to look into swapping out your front differential drivers side needle bearing and replacing with East Coast Gear Supply bushing.
  12. Mar 29, 2017 at 12:24 PM
    #192
    ItalynStylion
    Steven
    DFW, Tx.
    I'm using the 2.5 degree shims too. With a double cardan joint, you want to point the pinion right at the transfer case.
  13. Mar 29, 2017 at 2:05 PM
    #193
    ptm
    ptm Well-Known Member
    East Coast
    2006 Tacoma TRD
    Magnuson Supercharger Bilstein 5100 w/ OME 887s and 3 Leaf AAL Progressive TRD Quickshift TRD Shifter Knob URD Stage III Clutch URD 3" SS Exhaust Diff Drop Performance Steering Bushings Stealth Custom Series 17" SR8s 285 70 17s Toyo Open Country AT IIs Leather throughout, include leather padded steering wheel, shift boot and armrest HomeTaco Grill
    Not sure if it vibrates in 4wd. I'll give it a run but I need the right conditions to do it. thank you for the insight
  14. Mar 29, 2017 at 5:34 PM
    #194
    Longshoreman
    Longshoreman Well-Known Member
    CA.
    2013 Tacoma off road & tow package
    Toytec coilovers Fabtech uca's Dakars and 5100's in the back.
    So under a moderate load it doesn't come up (wrap) too far.
    I wonder if I put the 2.5 or maybe a 2.0 in if it would help me. I've got just very slight vibes below 8mph on acceleration with a two peice. Got there by dropping the cb. Trying to not have to sink more money ya know........
  15. Mar 29, 2017 at 5:52 PM
    #195
    ItalynStylion
    Steven
    DFW, Tx.
    I have a local shop welding in a 1310 double cardan joint behind my OEM carrier bearing just like @1MK had originally. I specifically asked my guy if he had to use a smaller diameter shaft or spine segment to make it work and he said no, he wouldn't need to change any of those things. It should be noted that he's modifying the OEM shaft and not starting from scratch (which is what I really wanted) so I SHOULD end up with a full strength shaft with a 1310 double cardan joint. It should be done tomorrow or Friday. Waiting on pins and needles here. Stay tuned.
    gordi and samiam like this.
  16. Mar 29, 2017 at 6:05 PM
    #196
    Longshoreman
    CA.
    Sounds like you got a good shop. Stayin' tuned...
  17. Mar 29, 2017 at 7:14 PM
    #197
    ButtaYoBreadd
    ButtaYoBreadd Well-Known Member
    2014 TRD OR DCSB
    Hi all, prospective Tacoma buyer here. The abundance and lack of solution to this issue has made me nervous to buy one :( can anyone tell me if this is limited to 4x4s? Or maybe just lifted trucks? Or possibly a range of model years? Thanks for any help! :)
  18. Mar 29, 2017 at 8:17 PM
    #198
    ItalynStylion
    Steven
    DFW, Tx.
    Really just lifted trucks for the most part. Some people say they have some vibrations on stock suspension but I believe the majority of the people experiencing the issues have lifted the truck which changes the geometry of the shaft angels.
    Try not to worry about it. You're buying a quality truck.
  19. Mar 30, 2017 at 4:04 AM
    #199
    bubba353z
    Columbus, Oh
    I've got the 15-25 mph vibe on a 100% stock Sport, but it's not so bad I'd consider getting rid of the truck over it. I'm thinking about the TW driveshaft, but it's not a top priority right now....
  20. Mar 30, 2017 at 7:22 AM
    #200
    TacoRob08
    Rob
    17 Sport DCLB
    Looking forward to how this works out.
