Single (and Two) Piece Driveshaft = Vibes....BE GONE!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Feb 16, 2017.
  1. Apr 4, 2017 at 5:14 PM
    #261
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    First hand experience says this is true.
  2. Apr 4, 2017 at 5:21 PM
    #262
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Even if it's a thicker gauge tube? But same 3in diameter
  3. Apr 4, 2017 at 5:26 PM
    #263
    Fox2011PM
    Fox2011PM "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    S
    Should be 3.5" or 4.0", don't think Tom Wood's go smaller than 3.5"
  4. Apr 4, 2017 at 5:39 PM
    #264
    90yota
    88 T4R / 15 F350
    Stock....ish
    Right whatever the stock size is. Does anyone know what gauge tube is used on stock vs tom woods?
  5. Apr 4, 2017 at 9:03 PM
    #265
    klikboom
    klikboom Well-Known Member
    SNOHOCO
    Taco
    The speed at which a shaft whirls is related to its stiffness and mass and length. Bending Stiffness is a function of area moment of inertia, you get more bang for your buck (and lb) to grow diameter as much as you can before significantly thickening wall.
    90yota[QUOTED] likes this.
  6. Apr 5, 2017 at 3:11 AM
    #266
    90yota
    88 T4R / 15 F350
    Stock....ish
    Thank you
  7. Apr 5, 2017 at 6:24 AM
    #267
    klikboom
    SNOHOCO
    Taco
    Installed the TW 4" shaft last night . I used a cutoff wheel to remove the whole center section of the center bearing support cross member. Takeoff vib is eliminated it seems, didn't drive much at highway speeds but it feels like a SIGNIFICANT loss of power? At low speeds i didn't notice anything but 60-65 feels like my motor really has to work harder now to keep things spinning.
  8. Apr 5, 2017 at 6:56 AM
    #268
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Manual or auto
  9. Apr 5, 2017 at 7:23 AM
    #269
    klikboom
    SNOHOCO
    Taco
    4.0 -Manual 6sp -DC
  10. Apr 5, 2017 at 7:56 AM
    #270
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    o.k...let's trouble shoot this together, we need to start with the basics - did you drop acid before the test drive ?
    TomTwo and nDub like this.
  11. Apr 5, 2017 at 8:06 AM
    #271
    klikboom
    SNOHOCO
    Taco
    Lol, not that I know of!?! Ya "feeling" power is terribly subjective but sure felt real. I only took a 5 min drive on interstate, will drive it for a couple weeks and see how it goes. Sure was nice to be vibe freeish (I'm still in that paranoid phase of feeling every bump in the road and thinking it may be vib)
  12. Apr 5, 2017 at 6:57 PM
    #272
    1MK
    1MK Desert Explorer
    Southern California
    Got the driveshaft back today, and unfortunately it's still about the same. I'll end up returning it. Super bummed as I really wanted it to work as driving feels so solid and connected with the one piece.
    For those thinking about going this route, my truck is heavily modified compared to stock. Lot's of weight, spring under conversion, gets driven hard off-road, etc. So don't let my experience sway you too much. I wouldn't hesitate to order from Tom Woods and they have been nothing but amazing to deal with.
    Anyone got a stock on they want to part with? V6 - Doublecab - Shortbed - 4wd
  13. Apr 5, 2017 at 7:31 PM
    #273
    klikboom
    SNOHOCO
    Taco
    This could be a good excuse to add a taco box crawl box which would shorten your driveshaft and maybe let you run single piece and crawl like a sob.
    Bobcdn and nDub like this.
  14. Apr 5, 2017 at 7:33 PM
    #274
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    If I break my shaft I will be coming here to buy one
  15. Apr 8, 2017 at 6:14 AM
    #275
    evskie53
    evskie53 The Problem Child
    Denver
    2011 DCSB Sport
    Did anyone else need longer bolts for the rear flange on their new Tom Woods drive shaft? If so, what did you use?
  16. Apr 8, 2017 at 8:20 AM
    #276
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    no, are you sure that you have it seated properly ?
    post a pic
  17. Apr 8, 2017 at 8:49 AM
    #277
    evskie53
    Denver
    2011 DCSB Sport
    Just going off of the new flange thickness it looks like the stock bolts will be around .200" short. Haven't mounted anything yet.
  18. Apr 8, 2017 at 8:57 AM
    #278
    evskie53
    Denver
    2011 DCSB Sport
    New flange thickness is .175" thicker than the stock flange.
  19. Apr 8, 2017 at 3:01 PM
    #279
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I recall there being plenty of extra thread left on the stock shaft flange. Even with 0.175 more on the TW flange I would think it would still have enough. Did you try and put the bolts through yet with the flange surfaces mated flush with one another?
  20. Apr 8, 2017 at 3:12 PM
    #280
    1MK
    1MK Desert Explorer
    Southern California
    I love driveshafts!!!
    Ha.
    4 hour round trip today to pick up a used stock assembly. Replaced all the u-joints and carrier bearing. Got them take off vibes again but it's smooth all the way to 85 mph. May be able to get it a bit smoother playing with angles and since I don't have severe axle wrap like a spring over setup should make setup a bit easier and manageable.
    Good times.
    samiam and Bobcdn like this.
